Go to Post [In FIRST]...Arab and Israeli students speak on the same level, because they are alliance partners. - Tottanka [more]
Unread 14-02-2012, 15:54
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Averaging one side with Encoders or two wheeled drive?
So I was talking with the programmers, and being that we were doing six wheeled drive with 4 CIMS using 2 Victors, we figured we'd need 4 encoders. Now, my question is what would be the better approach?
1. One encoder on each shaft with only one channel wired. Then I'll direct the Encoder class towards the two Encoders on the same side and two for the other side.
2. Power only 2 motors for PID and have two fully wired Encoders on those shafts.
EDIT
This is for autonomous PID drive
Unread 14-02-2012, 16:12
Re: Averaging one side with Encoders or two wheeled drive?
Originally Posted by kinganu123 View Post
...4 CIMS using 2 Victors...
You'd better fix that before you do anything more fancy. Each motor requires its own speed controller.
Are both motors on each side connected to the same gearbox? Are all the wheels driven by the same gearbox output? You only need one encoder per gearbox.
Unread 14-02-2012, 17:23
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
I believe that is a rule, correct?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 14-02-2012, 19:18
FRC #1747
All motors are mounted onto on of two nanotubes by andymark, which has a uniform gear ratio. But I was told that not all motors were created equal, which is why I figured 4 Encoders would be better
And R50 is a bit vague in my opinion. Not entirely sure if its legal or not...
Unread 14-02-2012, 19:20
Look at rule [R46].
Unread 14-02-2012, 19:54
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If two motors are mechanically geared together, they will spin the same speed.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-02-2012, 20:04
FRC #1747
they aren't
they are just housed in the same gearbox
Unread 14-02-2012, 21:28
And if two motors are driving traction wheels on the same side of a robot, one can reasonably assume that they will be spinning the same speed...at least when driving straight or mostly straight. When one wheel is slipping more than another, it's not always easy to decide which one is the best wheel to use as a speed reference. I'd just use two encoders, connected to the section of the drivetrain having the wheels with the most weight on them.
Unread 14-02-2012, 22:35
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
they aren't
That's the definition of "mechanically geared together". The CIMple boxes in the kit have encoder shafts which are designed for the US Digital encoders which also happen to be in the kit. You only need two since you only have two output shafts. The encoder shaft is actually the same piece of metal as the output shaft, so you don't have to account for any gearing.
Unread 15-02-2012, 00:30
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I believe the OP is saying that they are in the same, physical box, but driving two distinct gear trains. Actually, I know this to be the case since the gearboxes used were listed as AM Nano Tubes, of which six stock variations exist, all of which only accept one motor per gear train.
Unread 15-02-2012, 00:42
You don't need 4 encoders. Limit your acceleration and as Alan already said, put the encoders on the heavier side of the robot. Should be fine.
