Go to Post Good programmers always find a better way to do something, especially when it's not obvious where those improvements can be found. - Mr. Lim [more]
Unread 14-02-2012, 22:01
RoboticX3Kitty RoboticX3Kitty is offline
FRC #4038
RoboticX3Kitty is an unknown quantity at this point
Window Motor Screws
Does anyone know what size screws we should be using with the window motors?
Unread 14-02-2012, 22:07
VKP's Avatar
VKP VKP is offline
VKP
AKA: Vivek Paramasivam
FRC #1899 (Saints Robotics)
VKP is an unknown quantity at this point
Re: Window Motor Screws
Do you mean the Denso motors or actual "window" motors?
Our team has drilled 1/4" holes into the Denso Motor holes to fit bolts that size.
Vivek
Treasurer, Senior Build Officer, Saints Robotics 1899
Seattle Olympic Regional Chairman's Award 2011
Seattle Olympic Regional Winner 2011 (Thanks 2990 & 3393)
Seattle Olympic Regional Best Website Award 2011
Unread 14-02-2012, 22:46
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
You aren't allowed to modify the motor.
Originally Posted by R49
Motors, servos, and electric solenoids used on the Robot shall not be modified in any way
Unread 14-02-2012, 22:47
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
You missed the rest of it.
[R49]
Motors, servos, and electric solenoids used on the Robot shall not be modified in any way, except as follows:
A. The mounting brackets and/or output shaft/interface may be modified to facilitate the physical connection of the
motor to the Robot and actuated part.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-02-2012, 23:00
cgmv123's Avatar
AKA: Max Vrany
[R49]
The phrase "motor holes" implies the actual electrical part, but fair enough.
Unread 15-02-2012, 00:01
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Someone didn't read the rest of the rule.
[R49]B. The electrical input leads may be trimmed to length as necessary.
[R49]D. The connector housings on the window motors (PN 262100-3030 and 262100-3040) may be modified to facilitate lead connections.
That being said, to answer the OP's question, the window motor was designed to use metric screws; M5s in particular if I'm not mistaken. I would recommend either reaming out or drilling the holes so that #10s can be used; drilling out to 1/4" is less advisable but just as functional.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 15-02-2012, 05:05
mehrkam's Avatar
mehrkam mehrkam is offline
Paul Mehrkam
FRC #0836 (Robobees 836)
mehrkam is on a distinguished road
If I remeber correctly, the threads are Metric, M-6.
We also, drilled most of ours out.
Good Luck.
