Go to Post You heard it here first folks. The robot will definitely need wheels and will probably have an arm. - DampRobot [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 14-02-2012, 23:30
Captain Slacker's Avatar
Captain Slacker Captain Slacker is offline
FRC #0571 (Team Paragon)
Captain Slacker will become famous soon enough
arduino help
I know it's build season, but I really need some help and I figured i'd give it a shot
i have an arduino uno board and have to run it on a 9 volt batteryand then run a 3v dc motor from the board starting with a 45 second delay then run the motor for a second then shut off
how would i do this i need help setting up the circut and programming it i would preferably like to use the blink code with and output on a digital pin but if you have any other ideas let me know
i should be able to run the motor with the power from the board and just have the battery supply power to the board itself
Thanks! btw this is my girlfriend's account. the name i'll be responding with is daignaultz
Who Rocks This House?!
PARAGON!!!
Unread 14-02-2012, 23:41
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
MAldridge will become famous soon enoughMAldridge will become famous soon enough
Re: arduino help
for the wiring, a darlington configuration H -Bridge is your best bet
to run the motor, you'll do a pwm_allocate, then a pwm_write() (I think that those are correct). the delay is just a sleep function. If you have any trouble let us know.
As a second thought, depending on your electrical skill, you might consider investing in one of these: http://www.pololu.com/catalog/category/97
'Why are you a programer?' --Team Captain
'Because the robot isn't complicated enough!' --Me
Unread 14-02-2012, 23:54
Re: arduino help
i do not have an h bridge but i only need it for one directionality shoulding i be able to power the board and then just power the motor from the board and control it with a delay
PARAGON!!!
Unread 14-02-2012, 23:58
MAldridge's Avatar
Lead Programmer
AKA: Rube #1
Re: arduino help
pardoning the broken speech, a relay will sufice if you just need the motor to spin one way.
You should NEVER source drive current from an arduino. Each pin is wired for only 20ma. You should source your motor current from the main bus rails of whatever you are building. If you are bent on only needing 3.3v, then you should use something like an LM317 to drop the voltage.
Unread 15-02-2012, 00:39
Re: arduino help
how would i set up a relay for the motor?
PARAGON!!!
Unread 15-02-2012, 22:22
MAldridge's Avatar
Lead Programmer
AKA: Rube #1
Re: arduino help
http://www.instructables.com/id/Conn...ay-to-Arduino/
the relay uses a 12v coil, but the same steps apply to using a 9v one
Unread 16-04-2012, 12:01
kalfuswi kalfuswi is offline
AKA: Billy K
FRC #1676 (Pascack Pi-oneers)
kalfuswi is an unknown quantity at this point
Re: arduino help
Here the code you could use:
connect an NPN transistor driving a motor to pin 9 on arduino
int motorPin = 9;
void setup() {
pinMode(motorPin, OUTPUT);
delay(45000);
digitalWrite(9, HIGH);
delay(1000);
digtalWrite(9, LOW);
void loop() {
William Kalfus
Team 1676, The Pascack Pi-oneers
