Go to Post I'd say start working on other forms of wireless communication. Scout using Morse Code, hand signals, light flashes (LOST anybody?)... Paper cups and string are cheap too... - AndyB [more]
Unread 14-02-2012, 16:49
Nate Laverdure's Avatar
FRC #2363
[FTC]: TETRIX gear specs
For posterity:
TETRIX gears have a diametral pitch (DP) of 32 teeth/in, a pressure angle (PA) of 20 degrees, and a face width of 0.250 in.
Unread 15-02-2012, 02:47
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: [FTC]: TETRIX gear specs
I'm lost as to what the purpose of this was?
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 15-02-2012, 07:51
FRC #2363
I thought I explained it pretty succinctly... I needed this information and I couldn't find it on ChiefDelphi or any other obvious place. So after doing the research to find the information, I shared it here for other people to use because I couldn't find a more appropriate place.
Unread 24-02-2013, 19:00
kk052's Avatar
kk052 kk052 is offline
CAD extraordinaire
AKA: kyle lundquist
FRC #2517 (the green wrenches)
Team Role: CAD
kk052 can only hope to improve
thank you for this info i found it usefill
Unread 24-02-2013, 19:55
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Originally Posted by Nate Laverdure View Post
For posterity:
I think they're actually 0.80 module based on the dimensions of the CAD models that I downloaded. 0.80 module is equivalent to 31.75 pitch, so a custom 32 DP gear would work fine in any case. I'm not positive that the models match reality. If one measures the outer diamter of a 40 tooth gear, then if it's closer to 1.313" it's 32 dp, and if it's closer to 1.323" it's 0.80 module.
Unread 03-11-2016, 17:25
gof gof is offline
FTC #10138 (Newton Busters)
gof is an unknown quantity at this point
For posterity:
Adding my thanks for storing this data. Just what I was looking for!
Unread 21-11-2016, 13:27
FRC #2363
Originally Posted by Forhire View Post
Tetrix gears are actually 0.8 Mod (31.75 DP) 20 PA. 32 DP is close enough for most things, but be aware it could affect your center distance. 0.8 Mod is common in rc parts so that may help your search. You may be able to source 20 tooth pinion wire. With a 20 tooth it won't matter 32 DP or 0.8 Mod. Pinion wire is fast just bore and part off to length. Press it onto the shaft. You can also turn a shoulder for set screws if it needs to come apart later.
Before I bought a set of 0.8 module cutters I used 32 DP cutters and metric OD... this kept my center to center distance correct.
Emphasis added. Thanks Dan and Randy for correcting me.
