Go to Post ...if most of the money comes from sponsors, I have a bit of a problem letting them [the students] charge off a cliff with it. - TimCraig [more]
Unread 14-02-2012, 19:02
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Exclamation crio setup
My team is having difficulty with the FRC crio II that we purchased recently. i followed the getting started guide and tried a few suggestions on CD (crio not in safe mode, ip is correct) but have not been able to get the crio imaging tool to find the crio. i have checked and have both the labview and ultilities updates installed. The setup worked with the 8-slot crio that we have right now but we wont be able to use it for competition. The 4-slot crio is out of the box with no settings changed so what steps do i need to take to get the crio to be reconized by the imaging tool and the driverstation?
Thanks in Advance
Jon
Expect the best, Prepare for the worst
Unread 14-02-2012, 20:42
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: crio setup
Is your windows firewall turned off? What is the laptop's IP address?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 15-02-2012, 01:24
AKA: Jon
Re: crio setup
yes the firewall is off. i have tried 10.9.32.1,10.9.32.2,10.9.32.5,10.9.32.6
Unread 15-02-2012, 04:22
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Re: crio setup
Try 10.9.32.51 also make sure you have it tethered via the ethernet crossover cable.
Unread 15-02-2012, 09:36
Re: crio setup
Some things to try:
  • Disable all other networks on your computer, so that only the Ethernet going out to the DLink-cRIO is Enabled. Do not just turn them off, actually go into the Control Panel and Disable them all.
  • Keep all your IP settings as they should be, moving them around can only hurt.
  • Use the DLink between your PC and the cRIO and keep everything to Ethernet cables until you get it imaged.
  • Anti-virus off, as well as, your Firewall.
  • Try a different computer.
Unread 15-02-2012, 09:42
Bharat Nain's Avatar
Re: crio setup
Also make sure you are not using last years imaging tool.. if you're using a laptop with software from previous years. That would work with the old cRio but not the new one (I think). The new one is labeled "FRC 2012 Imaging Tool".
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
