Go to Post So we dont need a brain to run the minibot? - TheGuyz [more]
Unread 14-02-2012, 22:38
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
Broken cRIO slot
So if you have a broken slot (busted pins), and you move the digital module from slot 2 to slot 6, Is it still module 1 or is it module 2? I know it won't take long tomorrow to figure it out, but I thought I'd ask :-)
Thanks.
Unread 14-02-2012, 22:52
Re: Broken cRIO slot
It should be module 2 and is not legal for competition (R57B). It should work fine for practice though.
Unread 15-02-2012, 05:25
AKA: George Boyce
Thanks. We won't send a damaged cRIO into competition :-), but I'll get the rule fixed. I'm sure the intent of the rule is on how to wire the signal, not where to place the module.
Unread 15-02-2012, 09:42
The purpose of the slot 2 rule is that the RSL will not work unless the Digital module is located in the second slot.
There is no RSL in any other slot..
