Go to Post I was watching the webcast when that score was posted and thought to myself, "What did they do, steal a donut from Dave?" - MissInformation [more]
Unread 12-02-2012, 16:23
kuh-nig-its-EL's Avatar
kuh-nig-its-EL kuh-nig-its-EL is offline
FRC #1939
kuh-nig-its-EL is on a distinguished road
Can't get CAN status
This problem has been posted in the CAN forum already but because this is primarily a programming problem and this problem has yet to be solved I have decided to bring it to the attention of the programmers of the wonderful world of LabVIEW. In my team's attempts to use CAN for the first time we have run into a problem. For some mysterious reason we are not able get the status from the jag. We have all the same components as the example for CAN, the speed controller version, implemented into robot code. From what I have read this problem has occurred with other teams this season but I am yet to find a thread with a solution. Any help would be appreciated.
-Ethan Lopez
Unread 15-02-2012, 09:01
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Re: Can't get CAN status
If you post your code, we can take a look at it.
Doug Norman
Unread 15-02-2012, 10:11
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
What kind of feedback are you looking for that you're not getting?
Unread 15-02-2012, 19:02
FRC #1939
Here are the pictures of Begin and periodic tasks
ID:	11918  Click image for larger version
Unread 16-02-2012, 09:23
I don't notice anything wrong with your code pictures. Does the example you took this code from work for you? You should make sure it does before you merge it into your robot code. If the example works, then post your actual code (not pictures) so we can try it.
Doug Norman
Unread 16-02-2012, 12:37
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
If you're using the encoders included in the KOP, try changing your encoder type from "Quad Encoder" to "Encoder". Also, double-check your encoder connections to the Jag.
You might consider getting an example working before trying this in a robot project.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 17-02-2012, 11:20
FRC #1939
The example code worked fine and the software designed to work the CAN worked as well. Here is the code itself, just periodic and begin.
