| I'll pick you up anytime. (with a claw) |
| Thread Tools |
Rating:
Display Modes |
Tips from a veteran Robot Inspector
Now that we are getting near robot completion it is now time to do some self inspection of said robot.
1) Go through the Robot Inspection checklist. 2) Be sure Main Breaker is where anyone can reach/see it. If your robot starts to smoke, during a match, wouldn’t it be nice if someone can quickly shut down your robot without having to hunt for the OFF switch? 3) One wire per Wago slot. 4) Confirm proper wire gauge, per application, per breaker. 5) Sharp corners. Remove them. I don’t like seeing blood, especially my own 6) Place air pressure gauges where they can be seen clearly. 7) Confirm any appendage cannot go further than 14 inches. 8) Bumpers. Use ¾ inch thick by 5 inches tall plywood, 8 inch minimum length. I have seen teams use ½ inch thick plywood and have to rebuild all their bumpers at a regional before they were allowed to play. Don’t be that team. 9) Bumper Zone is 2 inches to 10 inches. 10) Battery securely contained in robot. I have seen too many robots, during a match, dragging their battery. At the regionals: 1) Don't wait till the last minute to have your robot inspected. You will avoid the rush from the other teams who waited till the last minute. 2) Don't get mad at the inspectors if they ask you to make some changes. They are only trying to help you have a great regional experiance. Last edited by Wayne Doenges : 15-02-2012 at 08:28. |
Re: Tips from a veteran Robot Inspector
I took a look at what my students had cut so far for the bumpers and caught this exact problem yesterday. Thanks for the reminder list!
I second this. Last year we made the mistake of not securing our battery before an Elimination match and it was thrown from the robot about 20 seconds in.
We do this regularly; it gives us a chance to have a fun, relaxed interaction with the inspectors. They've given us lots of tips - both design and strategy. Inspectors, referees, field crew, administration - they're all good people, and they've all been in your position before. Take the time to make good relationships with them. It'll pay in spades. Last edited by Taylor : 15-02-2012 at 09:48. |
Thirded with emphasis. Also, anything that's elastic doesn't count as secure. We lost the '07 Great Lakes Regional for 1114 because I assumed another mentor purchased a proper battery strap and it turned out to be elastic. After technical difficulties in Semi 1, we went out in Semi 2 without a bumper that covered our battery. All that was holding the battery in was this elastic strap. Someone hit us hard enough to rocket our battery out of the robot and there goes what should have been an epic trophy for my team.
Quoted for truth. That little breaker gets exponentially harder to find when you're trying to turn the robot off quickly while still being conscious of the safety issue at hand. Print off the nice, red-and-white striped sticker from FIRST and put it on before the competition, and everyone will be happy.
#7
Al's Annual Inspection Thread.
Now that we are less than a week to Stop Work Day, (and since a new Inspection Checklist was released last night) it is time to remind all teams that robots need to be inspected before all competitions. As it appears that many teams are choosing pneumatics this year for some functions, let's start there.
1. The compressor used to charge the robot storage system must be an FRC legal compressor controlled by the Crio. If you choose to keep your compressor off-board, it still must operate under Crio control and all other robot rules must be followed. 2. Valves must meet the max volume spec of 0.32 Cv per R71. 3. Components may not be modified. This includes painting, grinding to remove weight, etc. You may remove the pin from a cylinder as long as the cylinder itself is not modified in the process. 4. Tubing can be a maximum of .160 ID and all tubing must carry a working pressure rating of 125 psi. 5. Working pressure must be supplied through one primary Norgren regulator at 60 psi. Working pressures less that 60 psi can be supplied through additional regulators downstream of the primary regulator. 6. The pressure relief valve is not calibrated from the factory. You must adjust it to open at greater than 125 psi. This can be accomplished by bypassing the pressure switch and adjusting the valve while monitoring the high pressure gauge. Be sure to tighten the locking collar and test again. 7. The pneumatic system will be checked during the "Power On" test portion of the Inspection Checklist on p2. Please have several of your students and one mentor assigned to checking over the Inspection Checklist prior to sealing the bag next Tuesday. It will save you considerable time at your events. Remember that when you inspect early, you get to go into the practice fill in line and get some extra practice time on the field. One quick reminder...The rules have changed this year for maximum size of the operator console. This is due to the ball return's size in the driver's station. [R82] The Operator Console must not exceed 44 in. long by 12 in. deep (excluding any items that are held or worn by the Drivers during the Match). |
#8
Re: Al's Annual Inspection Thread.
Are all previous year KOP valves considered legal?
#9
Doubtful. The 0.32 CV requirement is new enough that several years' KOP valves likely have not been vetted by FIRST. Also, inspectors are not typically provided with documentation for KOP valves, especially from previous years.
The best protection is to bring the manufacturer's documentation for the valve. |
#10
11) If you are using a chain be sure to put a guard over it, if there is any chance someone can get aan appendage caught in it
#11
This is all great advice. It is so importance to go through the checklist yourself, before build season is over. So, here's the official checklist:
1) Go through the Robot Inspection checklist. And, because there's been so much discussion about bumper length: 8) Bumpers. Use ¾ inch thick by 5 inches tall plywood, 8 inch minimum length. The 8" does not include any plywood in the corner (overlapping another bumper). You must have 8" from the vertex (corner of the frame perimeter). I hope this helps. Good luck, everyone! |
#12
Do you have a link to this? I don't remember seeing it on FIRST's site.
#13
What about protecting the shooter wheels? Our gears are relatively inaccessible but one could stick their hands into the wheel. Any comments or suggestions?
TIA Last edited by wireties : 16-02-2012 at 16:13. |
#14
Clearly marking it as a dangerous area (caution tape or Yellow/Black stripes) is better than nothing if some sort of physical guard is not possible because of other constraints.
#15
