#91
Re: The Ultimate Game-Breaker Robot: 2012 Edition
Though I do agree that the criteria this year aren't nearly as explicitly defined as they were in previous years. |
#92
You can add me to that list, too. Indeed, I'll go further and say that I would have been shocked had trollbots ultimately been allowed.
#93
If they wanted people on top only of the bridge they have had many places/opportunities to say just that, and should've done it when the manual was released. I judge the intent by the manual put jn front of me, not the animation (which is always declared unnofficial in terms of rules).The fact the gdc said twice in two official answers what the bridge was, then changed it weeks later is bad form and I expected more from them. This essentially means all QandA answers are not fully official as they can go back on them at any time, just imagine how much they could change, maybe they could make one of your strategies illegal and I can pretend it was obvious in an ignorant fact ignoring way. |
#95
#96
Does anyone else see the similarity between the "bridge problem" and the use of the term "vertices" for the frame? Some of the first words from my team members upon hearing the vertex-8-inch rule was "what if the robot is oval?" (having no vertices). Forget about how you might go about making 3/4" plywood bend around an oval, they were simply exploring what was meant by the given terms. The GDC has always been able to make their intention clear by specific wording to the desired effect. It is becoming apparent that the attempt to turn the rule book into some sort of street sign (word starvation) is doomed to failure. Particularly in a high-school context in which members are ALWAYS and constantly looking for imprecise statements and the way around rules. There's no furor about the vertex thing because no one is making a round or oval robot. Or are they?
#97
469 in 2010 couldn't hang. 71 in 2002 couldn't put balls into goals. 233 in 2006 couldn't load from the top, 25 couldn't pick up from the field. When discussing a strategy like this, I assume that's the only thing the robot will be good at. Sure, the GDC could've said that all robots supported by the bridge had to be above the plane of the top surface of the bridge, but then they'd void 179's style of hanging. |
#99
But they didn't.....
#100
The bridge was repeatedly defined as to include the Lexan. Are people just supposed to ignore definitions when they don't seem right?
#101
Once, I might add, in exactly that context.
G40: When the final score is assessed per [G37], a Balanced Alliance Bridge will earn points based on the number of Alliance Robots completely supported by the Bridge, per Section 2.2.5, as follows[...] The Q&A Question, asked under G40 was: A: What physical parts make up the bridge by definition? Essentially, where does the bridge begin and end? For example, does the welded structure under the bridge that the top connects to count as the bridge? Does the lateral bar that rotates with the bridge that count as the bridge? The answer, as we all know: The Bridge consists of all components included in the Bridge Assembly drawing, GE-12017. I agree they didn't mention every non-top-of-bridge surface directly, but where is the ambiguity in the direction of that question? G40 is about balance and complete bridge support, the question asks 'what parts make up the bridge?', and the GDC answered 'all of them'. In all seriousness, what did they think the question was about, if not balancing on parts other than the one the GDC apparently intended? Disclaimer: I have to say I view the FIRST challenges more as sports than engineering assignments in this regard. This is probably because I in no way see the GDC as my client--that place is reserved for my students with the GDC as mere facilitators. I really don't care about the GDC's intent after they give a ruling, but I understand that apparently leaves me in the minority. (I am in no way implying that anyone who disagrees with my sentiments doesn't view the students as their goal/client/whathaveyou. Most of the guys on the other end are absolutely excellent mentors and engineers. I'd venture they probably don't view the GDC as just facilitators, though.) |
#103
Looks like GDC just broke this game breaker with an answer to Jared's question:
Nice strategy, Jared. Way to look through the field construction docs, I read that answer and moved onto next Q. However, just like most game breaking strategies it is not what the GDC intended (some they leave legal anyway). I had a great deal of fun going for the game breaker in '02 (grab 3 goals), and tried to go the 469 route in '10. I understand the that if a strategy is dominating a game, it is natural to want to level the playing field (or lower the pitcher's mound). Unfortunately, the risk of the strategy becoming illegal (190 in '08) outweighs the reward for all but the most daring teams when considering game breaker strategies. I personally didn't like that form of bridge manipulation (jam ball ramp), but I love what Swampthing is doing. While I see strategic value in a class of small 3rd bots (cRIO in wheels) for balancing 3 during, I don't think it will be very fun to watch them during quals (since 3 bot balancing is worthless). Last edited by The Lucas : 15-02-2012 at 10:46. |
#104
If you can ignore the definition of the word "balance" also....
#105
I don't know what to say Andrew, we'll just have to agree to disagree.
For all of the future engineers reading this thread - you give me an answer like that quoted above in an interview and I will NOT hire you. Time is money and I will assume you are likely to waste both. |
