Go to Post One transmission to rule them all, one transmission to bind them... :p - artdutra04 [more]
Unread 04-01-2003, 20:02
D.J. Fluck
Posts: n/a
2003 playing field observations
For those at remote kickoffs or got to take a look at the field in Manchester, what observations about the surfaces can you make?
My observation: the skyway wheel has about as much traction on the top of the ramp as a sock on a freshly waxed floor....its that slick
Unread 04-01-2003, 20:06
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
I was amazed at the wire mesh- it sagged below my foot- and I was also amazed when I heard no part of the robot (wheels included) could protude through the mesh. Wheels/Treads are gonna have to be powerful and smooth all around.. (unless bumps are bigger than 1' by 1'
Unread 04-01-2003, 20:09
Scorpion515's Avatar
Scorpion515 Scorpion515 is offline
#0040 (Trinity Pioneers)
Scorpion515 is an unknown quantity at this point
Send a message via AIM to Scorpion515
I was there.
The wire mesh will support you quite well. It does sag, but I don't think it will be much of a problem.
The top, the white section is designed to have very little traction. It has enough that the robot does have control on top, however, pushing matches should be very interesting.
Jill
Trinity FIRST (40)
Semi-Finalist @ RiverRage6
Unread 04-01-2003, 20:25
Slyfox Slyfox is offline
#1037 (Scream)
Slyfox is on a distinguished road
Send a message via AIM to Slyfox
I noticed that the mesh has two layers, horizontal wires and vertical wires and the horizontal layer was put on top. It will be better for traction than if the vertical side was facing up. Maybe this year it will be better to have wider wheels.
Also, does anyone know the dimensions of the ramp?
I figured out that it is 2 feet high but I don't know what the other dimensions were.
..<::SLYFOX::>..
Unread 04-01-2003, 21:25
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
"The 4-foot wide by 12-foot long by 2-foot high game platform is located across the center of the playing field. The horizontal surface of the platform is High Density Polyethylene (HDPE). Both platform approach ramps are 8 feet long by 12 feet wide (three 4’ x 8’ sections). They are sloped approximately 14 degrees from horizontal and are surfaced with open 1” by 1” welded wire steel mesh. The top wires of the steel mesh will be oriented so that they will run parallel to the 12-foot dimension of the top platform. The approach ramps and ramp platform have a 2-foot-high, ½” thick, transparent polycarbonate wall along their outside edges. These walls extend down to the surface of the playing field."
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 04-01-2003, 21:30
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
Now, could a bump go into the mesh as long as it doesn't go though the bottem? Ex: a bump could be 1/4 inch?
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 04-01-2003, 21:42
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
From what I gathered yes you could. They said protruding through which I would assume means more than .25".
Unread 04-01-2003, 21:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
1/4 inch would be too much. I would say no more than 1/8 inch.
Can someone clarify this for sure: At the edge where the mesh and HDPE meet, which is higher, the mesh or the HDPE or is it a perfect edge?
Unread 04-01-2003, 21:46
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Well it clearly wasn't a perfect edge and I'm assuming that the HDPE is higher just because of how you would probably mount it. And You're right the mesh is more like 3/16" thick not 1/4".
Unread 04-01-2003, 21:48
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
The HDPE is higher. As for the mesh size, each bar is 1/8", and the horizontal bars are laid across the vertical bars, so you have a total thickness of 1/4". Thus, any bumps under 1/4" would most likely be legal.
Jeff Waegelin
Unread 04-01-2003, 22:00
aman aman is offline
#0365 (MOE)
aman is an unknown quantity at this point
Send a message via AIM to aman
Question # of Containers
Does anyone know how many containers are supposed to be in each column?
Our team thought when watching the NASA feed that it was 3-4-5-5-5-4-3 however the manual says something different. Can someone please clarify this. Thanks
Aman
Unread 04-01-2003, 22:10
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
slippery!!
wow, that top platform is very slick. we need suction cups or somethin.
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 04-01-2003, 22:20
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Re: # of Containers
Aman
3 across
5 across
7 across
7 across
7 across
Unread 04-01-2003, 22:24
Dinush Dinush is offline
Build Team!!
AKA: Dina Begun
#0912 (Iron Lyons)
Team Role: Student
Dinush is an unknown quantity at this point
Send a message via ICQ to Dinush Send a message via MSN to Dinush
Re: # of Containers
Aman
you got it right. in the manual they list the 'tires' of boxws from bottom to top: 7-7-7-5-3. Which is just the same as from side to side 3-4-5-5-5-4-3.
Good Luck!!
--> 2003: Winners of Canadian Regional. Thanks 1088 and 378!
El Jefe de 148
Re: Re: # of Containers
Originally posted by Bduggan04
3 across
5 across
7 across
7 across
7 across
The above list is horizontal rows, which is how the setup is published in the rulebook. aman, you were probably thinking of the vertical columns (which would be 3-4-5-5-5-4-3)
Jeff Waegelin
Posted: Picture of 2003 Stack Attack playing field Elgin Clock Rules/Strategy 0 04-01-2003 14:36
Can we use tape if it contacts the playing field? archiver 2001 1 24-06-2002 01:01
Looking for full playing field archiver 2001 1 24-06-2002 00:13
playing field updates? archiver 2001 0 23-06-2002 23:03
Many inexpensive playing fields archiver 1999 5 23-06-2002 22:57
