Re: Duct Tape? Anyone?
Duct tape is allowed on the robot, but use as a fastener might invite further scrutiny from inspectors, especially with regards to electrical compliance and safety. ? |
I would say that is accurate.
It boils down to this:
Can you use duct tape? Yes. Should you use duct tape? Probably not. |
As I have to frequently remind the students on my team:
"The only properly engineered use of duct tape is the sealing of air duct." If you are not sealing air duct (which I have seen duct tape used for on an FRC robot), then you are not using the proper material for the application and you have a design issue. |
Around here contractors don't even use it for ducts, because it disintegrates too quickly from the duct temperatures and exposure.
It's been ingrained in me over the years that duct tape is always a big no-no on FRC robots, so I always assumed it was explicitly disallowed by the rules.
However, this year the students on my team wanted to use an 8" diameter air duct angling elbow as a passive angler for our shooting assembly and wanted to secure and smoothen the elbow joiners with ducting tape (to which I reacted -- illegal!!!). However, after looking over the rules and realizing that this is not actually an illegal material, this application seems a bit more appropriate to me. |
#7
It would help if we knew what the application was. Covering some bases...
*If you want to secure down a component: I'd say go to a local hardware store and get some Velcro. My two cents. *If you want hold frame members together: Not at all stable, and probably not safe. Find a different way to attach them. *As a covering: Id say ok on anything that doesn't involve electricity. *As a marker: We do it with our wiring. A parent gave us some gaffers tape, and we mark different wires and components with a certain colored tape, so we can easily determine which thing is attached where. Although it isn't necessarily duct tape, duct tape can be used in the same manner. besides, as far as I know, duct tape colors are far more widely available than, say, electrical tape colors. |
#8
We're using a bit of duct tape as a hinge for a low-load part. I can't think of an alternative to it that would work as well, |
#9
Have you used it? We've been securing our electronics with sticky-backed velcro for years, and it works brilliantly. The industrial strength stuff is quite awesome.
#10
If FRC trusts Velcro enough to keep the field elements secure while six 150 lb robots slam into them, we'll trust it with our Victors. |
#11
Clark,
Electrical tape is actually available in at least all EIA colors. The 3M color wheel, Digikey part STD-C-ND, although a little expensive is ideal for wire marking. Joe, I am not sure using duct tape for a hinge could be considered anything other than a fastener. There has got to be a better device. |
#12
I would always bring a roll of duct tape for emergency repairs at competition but would never use it to build the robot other than prototyping. |
#14
![]() http://www.lbl.gov/Science-Articles/...tape-HVAC.html |
#15
A few years ago the rules were changed to allow tape. It might have been the year after the "non-stick pad vs. non-stick tape" debacle. (If a product was labeled as a non-stick pad it was allowed, but if it was labeled as tape it was not. Talk about lawyering the rules.)
Anyway, I remember someone from the GDC, probably Dave Lavery, commenting that while tape was now legal don't go overboard and make them ban it again. |
