Go to Post Wait, we have to be logical? - JaneYoung [more]
Unread 15-02-2012, 15:53
techno4229 techno4229 is offline
AKA: marcus
FRC #4170
techno4229 is an unknown quantity at this point
Button motor control...
Hey were a rookie team and im trying to configure the default file of labview and what im trying to do is have ex: button 6 move 1 motor forward, then assign button 7 to move the same motor but reverse? how do i do it?
Unread 16-02-2012, 07:59
Re: Button motor control...
Search the forums for "motor button" and you'll find lots of suggestions. Here is a good one.
Unread 16-02-2012, 16:12
AKA: marcus
FRC #4170
Where is the "buttons" control and where are those triangle shaped codes? cant find anywhere btw ty for post helpful just rookie
Unread 16-02-2012, 16:20
plnyyanks's Avatar
plnyyanks plnyyanks is online now
Data wins arguments.
AKA: Phil Lopreiato
The triangle thing is a Select Node. If the boolean wired to the middle is true, then it will output the value wired to the top input. If the boolean is false, it will return the value wired to the bottom input.
The "buttons control" is an Unbundle By Name function. It takes a cluster input (the output to Joystick Get) and will "split" it up into its individual values.
As for controlling a motor via two buttons, I like to do it the attached way.
Name:	button motor drive.png
Unread 20-02-2012, 12:03
AKA: marcus
FRC #4170
ty helped alot now i need 1 more thing... setting the pwm control to a number how do i set it?
Unread 20-02-2012, 12:12
dcarswell's Avatar
dcarswell dcarswell is offline
FRC Mentor/Old Dominion University
AKA: DeAndre Carswell
FRC #3359 (Royal Robotics)
dcarswell is an unknown quantity at this point
this is another way of approaching the problem you are having..and as you can see you can change the speed of the motor, to your liking..we needed to slow a motor down, so instead of using 1 and -1, we used .4 and -.4
Name:	Motor Example to Button.jpg
Unread 21-02-2012, 18:47
AKA: marcus
FRC #4170
Exclamation Re: Button motor control...
just realized... umm, we need to control a total of 2 motors but separte funtctions ex:
motor 1 (move when one of the 2 buttons pushed) 2 way funtion - button
1fwd and button 2reverse
motor 2 (move when one of the 2 buttons pushed) 2 way funtion - button
3fwd and button 4reverse
but on buttons so if i use this on the robot main config file and put it in the teleop file, how can i do that its not just one motor is two in same project but seperat... so i can save pwm's
Unread 21-02-2012, 22:57
If you want to control one motor with two buttons, and another motor with two other buttons, just put another copy of the code next to the first one and change the buttons and refnum name.
