Go to Post All the gangstas in FRC have solid gold CRios. It's called "blingage". If you don't have a solid gold CRio, you're not a straight-up G. :D - Jamie Kalb [more]
Unread 15-02-2012, 15:54
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: PID Velocity Control
Originally Posted by RufflesRidge View Post
The Encoder Get VI has a Rate output at the bottom that takes care of quite a bit of that for you. The output is in pulses per second so you will have to scale appropriately if you want RPM.
Wow its good that I didn't see that before and waste a few hours trying to figure this out.
So it gives me the rate of the encoder perfectly?
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
