Go to Post If you want to know how to build a more competitive robot, ask. GP demands we tell you, help you, guide you, teach you. - Al Skierkiewicz [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 15-02-2012, 15:58
dsirovica's Avatar
dsirovica dsirovica is offline
Programming and Electrical Mentor
AKA: Dean Sirovica
FRC #1458 (Red Ties)
dsirovica is on a distinguished road
Re: CANbus Jaguar control
Thanks for the code sample - great idea to do Master-Slave via Voltage.
I am confused about Voltage vs. kPercentVbus. The latter is I assume the PWM duty cycle, the former surely cannot be analogue voltage driving the motor, as that would generate immense heat in the Jag. Again very inadequate documentation on this.
Q: why did you use 360 and not the full 1440 counts per revolution (the QuadEncoder max of the KOP encoder)?
I will try your approach and report back. It sure would be great to use the LM3S2616 puppy in the Jag!
Thnaks,
Dean
