Go to Post You know you are addicted to FIRST when you have trouble describing it because you realize it truly is way more than just a robotics competetion. - vivek16 [more]
Unread 15-02-2012, 17:08
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: How to fit klipring
You use a lathe, and lathe in groves of the correct size into the shaft were you want the clip to sit.
Then you force the clip into the groove with a flat head or something.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
