Go to Post Yeah, if we didn't have robots then we could concentrate on all that outreach stuff! - marshall [more]
Unread 14-02-2012, 20:29
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Things You Shouldn't Do
Never, ever drill a hole in a block of wood unless it is clamped down. Our team captain lost a large part of her finger this way.
Unread 14-02-2012, 21:20
Trez's Avatar
Trez Trez is offline
FRC #3606
Trez is an unknown quantity at this point
Last year we were cutting a piece of plywood on a table saw. The newly cut piece of wood got lodged between the saw blade and the sliding guide and shot 20ft clear across the shop making a large hold in the wall.
Prototype, Prototype, Prototype
Unread 14-02-2012, 21:52
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Lexan + same set-up + me standong there = Ouch
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 14-02-2012, 23:41
krazyman1013's Avatar
krazyman1013 krazyman1013 is offline
FRC #0701 (RoboVikes)
krazyman1013 is an unknown quantity at this point
Make sure everything on the CNC work tray is clamped down or the material will spin on the bit at approximately 2500 RPM until the bit breaks.
If it doesn't work torque it.
Unread 15-02-2012, 08:12
Nate Laverdure's Avatar
FRC #2363
That's called kickback, and it's one reason why the table saw is probably the most dangerous tool in your shop. Please be careful!
Unread 15-02-2012, 08:39
FRC #1836 (MilkenKnights)
Don't use bad PWMs. Also, don't connect PWMs backwards.
Unread 15-02-2012, 08:50
patrickr41's Avatar
patrickr41 patrickr41 is offline
2011 GSR Rookie Allstar 2012 GSR Mo
AKA: Pat
FRC #3467 (Windham Windup)
Team Role: Student
patrickr41 is an unknown quantity at this point
never trust the robot when its on
we lost connection with it and it went after the whole team
robot+lose connection=sprang ankle and no more camera turret
don't forget when your working on it to put it on blocks......
Unread 15-02-2012, 09:19
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Neophyte team member sent to deburr a hole in a plate... 30 seconds later, we hear a loud sound and I spend the next 30 minutes extricating said plate from deep within the belt sander...
Unread 15-02-2012, 09:57
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
DO NOT! go up to your team's CAD computer and decide it would be funny to mess around with the design. While fixable with 'undo' or 'ctrl z', it is really annoying and not remotely funny. One time a rookie even accidentally caused the computer to freeze up, making me have to re-CAD everything I had been working on
Do: Constantly save your CAD drawings
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 15-02-2012, 12:15
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
This happened to us a week ago. If you need to drill holes in a plate, and the holes are right above an encoder, NEVER EVER drill them without removing the plate!!!
That encoder took too long to replace
Unread 15-02-2012, 12:22
treffk's Avatar
treffk treffk is offline
botgirl
AKA: Kelli
FRC #1802 (Stealth)
treffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud of
Do not try to see if the battery fits and accidentily touch the battery terminals to the frame causing sparks and the unfortunate nickname of Sparky.
Also do not forget to put the tailgate up on the truck you are hauling the robot in. You will make a turn and the robot will fall out on the highway.
"If you always says yes, what are your yeses worth?"
Alumna of FRC Team 1802
Unread 15-02-2012, 17:17
caltemus caltemus is offline
AKA: Charlie
FRC #0195 (CyberKnights)
caltemus is just really nicecaltemus is just really nicecaltemus is just really nicecaltemus is just really nicecaltemus is just really nice
Do: Insulate your batteries the INSTANT you get them. I thought everybody did that...
Unread 15-02-2012, 18:26
dudefise dudefise is offline
FRC #2637 (Panthers)
dudefise is an unknown quantity at this point
We had a 2-cim shooter setup, and wired the positive wires from each motor to one jaguar, and the negative wires to another! Thankfully, the jags survived and seem to have avoided any damage.
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
Unread 15-02-2012, 19:34
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
MIssin' the MItten
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Originally Posted by electron View Post
Things to not do:
-Think you can worry about wire management after everything is wired.
-Put the Digital Sidecar in the most out-of-the-way, hardest-to-reach place on the robot you can possibly imagine.
Things to do:
-Make sure the jags are not wired backwards..
We actually did a similar thing, putting power into both sides of a Jaguar, and found that it was unresponsive afterward.
Unread 16-02-2012, 08:10
ianonavy ianonavy is offline
Programming Mentor/Alumnus
AKA: Ian Adam Naval
FRC #3120 (RoboKnights)
ianonavy is an unknown quantity at this point
Don't wire motors directly into the power distribution board and turn the robot on.
