Go to Post I will test first 'cause you cannot learn unless you break something first! - Andy Brockway [more]
Unread 15-02-2012, 19:09
NeatTeam NeatTeam is offline
FRC #1943
NeatTeam is an unknown quantity at this point
Re: Jaguar stops powering the motor after a few seconds
Originally Posted by Mark McLeod View Post
The Jaguar is protecting itself from the over-current.
A CIM is pretty robust and will handle it much better.
One way around the problem is to ramp the Jab in software.
Not always successful because the Jag gets increasingly sensitive to over-current the warmer it gets, so the ramp may have to get gentler over time.
A better way is to regear the CIM gear/sprocket train, but that's not always practical.
A third way is to switch to a Victor in this particular application, because it's a bit more forgiving, but the Victor won't protect itself, so there's a chance of burning it out.
When you say "ramp the Jab in software", do you mean to start at 0% and gradually raise the value?
