Go to Post Prepare to be surprised, amazed, awed, and inspired. - Alan Anderson [more]
Unread 15-02-2012, 17:17
kingkurry kingkurry is offline
FRC #4067
kingkurry is an unknown quantity at this point
Re: Spike Relay code failing
So does anyone have any suggestions?
Unread 15-02-2012, 19:17
mr_yes mr_yes is offline
FRC #1248 (The TITANium Allies)
mr_yes has a spectacular aura aboutmr_yes has a spectacular aura about
One non-programming possibility is that there is an intermittent electrical connection somewhere. We had one of those a few years ago, where the IFI controller would lose power when the robot leapt forward, causing the robot to...stop leaping forward. Doesn't sound *exactly* like your situation, but I can see scenarios where something like you are describing might happen.
Unread 15-02-2012, 20:27
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
Check your PMs.
I'm a mentor looking for a home in Southern California! I know Java, C++, electrical and mechanical.
Need Java or C++ help? Send me a PM!
Unread 15-02-2012, 22:23
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
It could really be a bad spike also. In fact, one of ours stopped working today randomly as well. We checked all the cables and nothing seemed wrong with them, then we tried a different Spike and it worked fine.
Unread 17-02-2012, 23:06
FRC #4067
Here are some photos of our wiring:
http://dl.dropbox.com/u/45939446/Robot%20Good.rar
Unread 18-02-2012, 20:56
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
we were helping a team at the Utah Regional and there connector on the spike wasn't working, we had to take off the case to get the connector in it, also today i tried wiring the spikes and put the PWM cable in wrong and busted the pins off it. So ya, they have been known to have connector issues.
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 19-02-2012, 11:00
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
You cant plug a relay into a pwm you have to plug it into a relay port right across from the pwm's. And also the b pin on the relay goes to the - one on the dsc.
Unread 26-01-2013, 13:41
synthmusic synthmusic is offline
FRC #3574
synthmusic is an unknown quantity at this point
Originally Posted by neal View Post
I would double check the wiring for powering the Digital Sidecar to 20 amps breaker. And also see if your team light is working.
THANK YOU! we spent a bunch of time looking at this, and then we found the sidecar had been wired to the camera power port based on this tip.
Check your power source...
