Go to Post buying an iPhone...$599. Monthly service charge...$59. Going to an Apple store just to post on CD... Priceless!:p - Schnabel [more]
View Poll Results: Are you using the ZomB Dashboard System?
Never heard of or tried ZomB 9 56.25%
Tried ZomB a few times 2 12.50%
Tried ZomB for a while 1 6.25%
Used ZomB only in previous years 1 6.25%
Using ZomB this year 3 18.75%
Voters: 16. You may not vote on this poll
Unread 15-02-2012, 21:21
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Judging from the number of downloads, ZomB is popular. Judging by the threads here on CD, its used by almost none. Our team wants to know if you use ZomB, and any good or bad experiences you've had.
(note: if you have used ZomB both in previous years and this year, select using ZomB this year)
Watchdog.Kill();
Unread 15-02-2012, 22:15
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Are you using the ZomB Dashboard System?
If SmartDashboard hadn't appeared, I probably would've.
Unread 15-02-2012, 22:25
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
MAldridge will become famous soon enoughMAldridge will become famous soon enough
we build a custom dashboard every year. Easier to tailer to our robot that way.
'Why are you a programer?' --Team Captain
'Because the robot isn't complicated enough!' --Me
Unread 15-02-2012, 22:29
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
Looked at it, but probably will end up using smartdashboard.
Realistically, I don't think we'll have any dashboard at all (ie: smartdashboard with nothing displayed). This is mainly due to a lack of student programmers to spend time doing nice things .
That said, I'm glad there is an opensource dashboard + driver station solution.
Unread 16-02-2012, 09:52
MikeNimmo's Avatar
MikeNimmo MikeNimmo is offline
Software
FRC #3126 (Flashpoint)
MikeNimmo is an unknown quantity at this point
We tried to use the ZomB Dashboard last year and encountered too many problems, so many in fact that we just ended up not using a dashboard at all during the competitions. More likely than not this was because, when we encountered problems, there was nobody we could easily consult with to deal with them. We, and also many other teams, have discovered that dashboards are much easier to use when we wrote them ourselves and knew every little factor about them.
As a side note, the functions of ZomB, although numerous and taco-filled, did not accomplish everything we wanted a dashboard to do.
Unread 16-02-2012, 22:25
byteit101's Avatar
could you elaborate on the difficulties? and what did you want it to do?
Watchdog.Kill();
Unread 16-02-2012, 22:59
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
All you need to know to make a dash is sockets... Which are fairly easy to work with. I will hopefully end up making something like a dash with java.
