Go to Post Quality has nothing to do with desire – you can’t wish quality. Quality has nothing to do with time, or money, or the other guy’s attitude. Quality has everything to do with craftsmanship. - Jack Jones [more]
Unread 15-02-2012, 23:31
agartner01 agartner01 is offline
Captain + Control Sys & Design
FRC #4174
agartner01 is an unknown quantity at this point
KOP rangefinder
So I tried hooking up the KOP rangefinder to the analog breakout, but when I run the program, the only output I get is 0. I can hear the rangefinder pinging, and when I hook up a voltmeter, there is a change in voltage when an object is placed at different positions in front of it.
How I hooked it up:
[/quote]
Code I used:
AnalogChannel *rangefinder;
rangefinder = new AnalogChannel(1);
std::cout<<rangefinder->getVoltage()<<endl;
Unread 16-02-2012, 11:38
Re: KOP rangefinder
You did plug the sensor into Analog Input 1 on the breakout, right? If it's getting power and outputting a voltage, you have the connector in the right orientation, but it might be on the wrong pins. Do you have code sending raw sensor input to the Dashboard?
Nothing else is configured for AnalogChannel(1), right? If you defined e.g. a gyro on that input earlier, trying to define the sonar sensor on the same input will fail. If that's the problem, I'd expect to see a message to that effect on the Driver Station diagnostic log.
