Go to Post That tetra has personality! - Kevin Thorp [more]
Unread 16-02-2012, 02:53
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
3647 up and runnning
http://www.youtube.com/watch?v=yfgZo...3JCQRh4SPI7mI_
http://www.youtube.com/watch?v=Pd2_E...3JCQRh4SPI7mI_
10inch pneumatic tires from skywaywheels and AM Toughbox Minis.
The last bit was caused when a bearing fell out of the gearbox, causing the small cluster to drop into the gearbox...
Shooter and the bridge lowering mechanism isn't attached in this video.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 16-02-2012, 05:23
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
Re: 3647 up and runnning
Nice robot! The rollers are very sleek.
If I may ask, what is the total reduction on the motor driving the rollers? (gearbox and pulley). It looks like a 550 with a 16:1 gearbox, but I cant guesstimate the pulley sizes.
I asked because we have 550's with 4:1 gearboxes and plan to use them, but we are afraid of them being undertorqued. It seems like yours is working fine, so we may want to try that reduction out.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 16-02-2012, 06:28
nlknauss's Avatar
nlknauss nlknauss is offline
STechnologyEM Teacher, Alumni
AKA: Nate Knauss
FRC #2729 (LC Storm Robotics Team)
nlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond repute
Our design called for banebot 550s with the 4:1 gearbox and an additional 2:1 reduction. We ended up having some issues with being undertorqued and have since switched to window motors. Our design had a belt system and compression plate combo.
Very nice robot 3647! Those wheels are awesome!
Nate Knauss
FRC 2729 Teacher-Drive Coach 2009-?, FTC 4390, FTC 7433
FRC 87 Student 2000-2002 and Mentor 2003-2006, FRC 1647 Mentor 2006-2008, FIRST Senior Mentor 2009-2013
"We can't change the cards we are dealt, just how we play the hand." -Randy Pausch
Unread 16-02-2012, 09:34
FRC #1836 (MilkenKnights)
Our design uses 2 550's with 4:1, so I was wondering if you were having trouble when using 2 motors geared together, or just 1?
Unread 16-02-2012, 13:24
Mk.32's Avatar
AKA: Mark
For the tower the gearboxes are 16:1 P60s with 550s then pulleys are 5inches [off mcmaster] to the PVC which is about 3inches in diameter. The original design called for 3inch pulleys for a 1:1 but a mistake with our McMaster order caused use to get 5 inch ones...
We have had no issue with toque; as you can see they fire up instantly.
Lots more photos in our blog linked my sig.
