Go to Post You won't find anything in school that says you have to share ideas or strategy with your football rivals. - Al Skierkiewicz [more]
Unread 16-02-2012, 08:13
Re: Unable to read accelerometer
Originally Posted by StephenNutt View Post
Additionally, we are currently using the old 8 slot cRIO. Has anyone managed to get the accelerometer going with last years cRIO rather than the new 4 slot cRIO?
Our programming testbed is an 8-slot cRIO. After we replaced the thick white 37-pin cable with the ribbon cable from the Kit of Parts, the accelerometer works fine with I2C.
You might have one of the boards that responds to the alternate address of 0xAC instead of the default 0x3A. Try changing that in the example code and see if it starts responding.
