Originally Posted by JamesCH95
That sounds dangerously like you're in the "not okay" regime of bumper construction.
[R28]
Bumpers must be constructed as follows (see Figure 4‑4):
be backed by ¾ in. (nominal) thick by 5 in. tall plywood.
hard Bumper parts (e.g. plywood, fasteners, etc) may not extend more than 1 in. beyond the end of the Frame Perimeter(see Figure 4‑4).
Figure 4-4
James, hank you for helping. I believe we looked at the pictures wrong when we designed our bumpers. We need to shorten the front bumpers so they only overlap the plywood backing of the side bumpers. Thank you again for drawing our attention to the issue!
Ross, the robot is not perfectly built. The frame is parallel, but the inside beams distort slightly downward. We built the front "arch" to force the frame back into shape, but it still says a little. We are continually monitoring the situation, but the problem seems to be purely aesthetical at the moment.
