Go to Post As part of this test phase, I would expect to see Aidan sleeping on the job for most of the upcoming season. :) - dlavery [more]
Unread 15-02-2012, 00:12
Clark Pappas's Avatar
Clark Pappas Clark Pappas is offline
Team Captain
FRC #4068
Clark Pappas is an unknown quantity at this point
Wheel shooter gearing
Hi CD,
My team insists that we want to gear the 550 motors for our launcher up. I've been lurking around other CD threads on shooters for awhile, and most teams seem to be gearing down. We are using a two wheel system, positioned horizontally in relation to the rest of the robot.
I'm using the equations mentioned in the first response to this thread: http://www.chiefdelphi.com/forums/sh...aunch+velocity
The only issue I'm having is that the free speed RPM on the 550 motors is not actually what we are getting (Obviously). How would I calculate a reasonable estimate of how fast our wheels are spinning?
One 550 motor on each wheel
Two 8" Lawn mower wheels (At least, that's what we are using as of right now. They weigh around 7 pounds)
P.S: Bear with my lacking knowledge of physics, I've only taken conceptual, and didn't pay much attention.
(Wth 4068)
2012 Colorado Rookie Inspiration award
(With 973)
2011 FRC Championship Winner
2011 Galileo Division Winner
2011 Long Beach Motorola Quality Award
2011 San Diego Industrial Design Award
2010 Las Vegas Finalist
Unread 16-02-2012, 02:11
tzjin tzjin is offline
AKA: Tony Jin
FRC #0192 (Gunn Robotics Team)
tzjin has a spectacular aura abouttzjin has a spectacular aura abouttzjin has a spectacular aura about
Re: Wheel shooter gearing
Our team typically uses the free speed to do most of our calculations. Truth is, you will probably be spinning quite fast since the wheels are under no load, but when the ball comes through, the impact will be pretty much impossible to calculate. Just test it.
But yes. Don't gear up those motors. I hear good things about Andymark's 3.67:1 gearbox paired up with six-inch wheels, though 8-inch may work too. You will most likely burn out those motors even if you direct drive them, and the wheels will take a very long time to speed up, and regain speed once a ball passes through.
With a smile,
Tony
Unread 16-02-2012, 06:27
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Clark, I would highly suggest gearing down to anywhere between 5,000 to 7,000 rpms. Free speed is way to darn fast.
-RC
R.C.
MadTown Robotics Team 1323
Unread 16-02-2012, 09:38
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
-RC
To echo what RC is saying not only is it too fast but it is DANGEROUS!
Mentor 2415
Unread 16-02-2012, 09:45
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
With 8" wheels you definitely want to gear the motors down. How much to gear down will depend on your configuration and desired range. In our experience single axle/hood shooters need to be geared 1/2 as much as a dual axle shooter to achieve the same distance. In other words, a single axle system has to spin twice as fast to get the same exit velocity.
For reference our design uses two 6" wheels on a single shaft with a hood with a 4:1 reduction using 2 FisherPrice (0673). We can shoot from the key and forward without a problem.
Unread 16-02-2012, 09:58
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Here's our setup:
BaneBot 4 7/8" wheels on top and bottom, each independently powered by an RS-550 with a 7:1 gear reduction.
We measured the current into the motors when it was running at "full speed" to be about 7A each. Plug that into Ether's Motor Calculator, and we see that the speed of the motors is 18007 RPM. That gives us a speed of 2572 RPM for our shooter wheels, which is quite sufficient (we can hit the center of the top backboard from midfield, when running at "full speed").
Now, given that we're using smaller wheels than you, you should take that difference into account - you need about 5/8 the speed we have to get the ball to go the same distance - or about an 11:1 gear reduction.
Unread 16-02-2012, 10:07
Method1:
Measure the motor current (at full voltage). Then you can use the motor curves to get an estimate of speed (see Jon's post#6).
Method2:
Temporarily mount an encoder or tach and read the speed.
Method3:
Fasten a small zip-tie to the motor wheel, then mount a small piece of card stock so the zip-tie hits it and makes a clicking sound once per rev. Record some audio of the wheel spinning then digitize it and run frequency spectrum analysis software to locate the frequency of the clicking.
Method4:
Borrow a strobe light with a strobing frequency readout. Find the fastest strobing frequency that stops the action*.
* paint a dot or put a small piece of tape on the wheel (see Jon's post#9) so you don't get fooled by stopping the action on the spokes - if it's a spoked wheel)
Unread 16-02-2012, 10:39
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Method3:
Genius! I've been trying to get some kind of tach together, but this one we can do with parts on hand. Thanks!
Unread 16-02-2012, 10:47
Method3:
hmmm... this is the only method we haven't used so far this year for our shooter, and now I want to try it!
We used a strobe (borrowed from work) on our prototype to figure out how fast it was going (it's easiest to tape a small strip of white paper on the wheel to to help you know when the action is stopped), since we were powering it with drill motors, and everything else seemed to complicated/long to figure out.
We measured the current to make sure the motors weren't going to burn out, and once we had that number, it was a fun little exercise figuring out the exit velocity of the balls (assuming no slippage).
We have encoders on the shooter to allow full PID control for accurate shooting. While I haven't seen it yet (programming has only had access to the robot for a couple of days), we are supposed to have distance detection working, and should be able to automagically adjust the shooter speed for a perfect basket every time.
Unread 16-02-2012, 11:12
To do this, are you planning to use test data in a lookup table, or use trajectory equations? Or perhaps some other method such as a math model whose parameters you tuned using test data?
Unread 16-02-2012, 11:27
That's a very good question... Unfortunately, I haven't worked much with the programmers, so I don't know what their strategy is! I think they were going to take it in to our practice field tonight to start working on making baskets, so hopefully we'll know if it works (and exactly how!) by this weekend.
Unread 16-02-2012, 11:28
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
We're using a single 8" wheel, offset flywheel with adjustable weights, and 2 BB550's through 4:1 transmissions and linked via chain. We're going to play with the belt cogs a bit, but right now they're something like a 16:36 reduction coming off the transmissions for about 2,000 RPM final speed.
It shoots very consistently from the key without the need for a spin-up time. We're working on range, range control while driving, and other minor tweaks though. We may also have to redo our shooter guide for less compression since the IFI 8" wheel has a very grippy tread. I suspect that's why we're falling short of our max theoretical range.
To control it (I think) we'll have an encoder with camera ranging and a lookup table for range:speed lookups. I'm not on the programming side, so that's just a guess.
Hope that gives you an idea of what to try. Good luck!
GitHub
Unread 16-02-2012, 12:29
Does this agree with your numbers?
69.8 feet/sec wheel tangential velocity,
34.9 feet/sec ball exit velocity,
38.1 feet theoretical* max range
* no drag, no magnus
Unread 16-02-2012, 14:34
JesseK's Avatar
FRC #1885 (ILITE)
It's at 55 degrees, so theoretical's a bit shorter than that. Plus the digital tach read anywhere from 1800-2000(ish) RPM's. I think I remember the theoretical being in the 30-34 foot range after adjusting with the tach's #'s. During our first tests we were more in the 24-25 foot range. Perfect for the key, but imperfect for our higher-order strategy (though even that strategy is still workable at the current range so we're not in panic mode).
GitHub
Unread 16-02-2012, 16:42
GW Kalrod GW Kalrod is offline
AKA: Nick Plante
FRC #0166 (Chop Shop)
GW Kalrod is an unknown quantity at this point
Send a message via AIM to GW Kalrod
Your team wants to gear a 19,000 rpm motor up?
I'd get a basic FIRST concepts/Physics concepts PowerPoint rigged up for your team.
KISS (otherwise known as the easiest way to not win.)
