Go to Post Pursue your passion whatever that may be and do not fault another for pursuing theirs. - Mr. Van [more]
Unread 16-02-2012, 00:23
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
694 StuyPulse 2012 Robot Reveal
Here is our 2012 robot JoeBot the Robot. He is named, in thanks to our long time sponsor Anne Moore, after our long time mentor and former coach Joe Ricci.
JoeBot is what we have been referring to as, and hope you to will refer as, a "Fender Bot". Unlike many other "Fender Bots" that have been shown so far, JoeBot can and for the most part will score on the top hoop against and away from the fender. Like 1114 and 217 from 2009 we are able to score from distance but our general strategy will be to score up close against the fender. We are able to score with robots in our way as well as from the key. JoeBot is also capable of crossing the bump as well as the bridge in order to reach the other side of the field.
Here are some specs on the bot:
Drive
-Eight wheel drive with 6inch pneumatic tires with an AM hub.
-Belt driven with modified AM shifters.
-High gear of 16fps and low gear of 4fps.
Acquirer/Conveyor
-Bottom rollers pick balls off of the ground and they are forced into the conveyor which runs to feed the balls into the shooter.
-The acquirer is an FP with an AM planetary with a 5:1 reduction.
-The conveyor is an AM motor with an AM planetary with a 5:1 reduction.
-There are light sensors within the conveyor to do things like move a ball up to make room for the next ball to enter the conveyor and bringing balls to the top while not sending them into the shooter while the shooter gets to speed.
Shooter
-Two BB775s with custom gearboxes that have a 5:1 reduction.
-Four Skyway wheels, 2 on each side to center the balls.
Tusks(Bridge Lowerer)
-Two 1.5inch bore pneumatics to raise and lower the tusks.
-Once the tusks are lowered, we drive into the bridge and it just tilts down as we begin to climb it.
We have had an up and down season but our final product, we think, is pretty good. The CAD was done, for the most part, by Jake Potter, known in the CD world as Ninja_Bait. It is by far the most thorough CAD we have ever had and it really helped us with the little things not going wrong.
We would like to thank a few teams for their role in inspiring this robot
-365, 254, 968 from 2006. The way you guys scored at the top of the ramp in 2006 was a big part of what gave us the "Fender Bot" idea.
-173 from 2002. You guys introduced us to polycord and we have been using it for years as a result.
-71 from 2002. Every year this "beast" inspires the ideas of 694 even if we never build a robot close to as awesome and dominating.
You will be able to see us in action at New York, Hartford and hopefully St. Louis.
We wish everyone the best of luck in Rebound Rumble!!! Hopefully we will be able to put together and post a robot video in the remaining days of build season.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 16-02-2012, 00:54
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: 694 StuyPulse 2012 Robot Reveal
Where do you get the 6 inch pneumatic wheels?
Unread 16-02-2012, 00:59
Po Taters Po Taters is offline
AKA: Joanna "Po" Zhu
FRC #0694 (Stuypulse)
Po Taters is an unknown quantity at this point
Originally, we ordered the 6" pneumatic hweels with steel hubs from mcmaster-carr (http://www.mcmaster.com/#pneumatic-wheels/=g9olkw Item #:2717T51). But we decided to swap them out for lighter, plastic ones so we mod-ed up some AM hubs to swap the steel ones with.
Unread 16-02-2012, 01:01
FRC #1836 (MilkenKnights)
It is amazing how similar our designs are. We are even mounting most of our pneumatics in the same spot.
Unread 16-02-2012, 01:05
Dripto Dripto is offline
AKA: Dripto Debroy
Team Role: Student
Dripto is an unknown quantity at this point
Originally Posted by Po Taters View Post
Originally, we ordered the 6" pneumatic hweels with steel hubs from mcmaster-carr. But we decided to swap them out for lighter, plastic ones so we mod-ed up some AM hubs to swap the steel ones with.
Specifically: McMaster-2717T51 with AM-0971's for hubs. We had to turn down the hubs to remove the outer wall, otherwise they didn't fit.
Unread 16-02-2012, 01:19
OZ_341's Avatar Unsung FIRST Hero
OZ_341 OZ_341 is offline
#0341 (Wissahickon)
OZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond repute
AWESOME LOOKING BOT!!
Hopefully we can play together again in 2012.
2010 Championship Chairman's Award
2016 MAR District Champion (thank you 225 & 1257)
2016 Galileo Division, #6 Seed, 9 W - 1 L
2016 MAR District Innovation in Controls Award
2016 Westtown District Finalist (thank you 4954 & 484)
2016 Westtown District Imagery Award (It took 17 yrs)
2016 Hatboro District Judge's Award
Overall Record 49 W - 21 L
Unread 16-02-2012, 01:26
jblay's Avatar
AKA: Joe Blay
We gotta, somehow, make it 3 years in a row.
Unread 16-02-2012, 01:28
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Nice looking robot, such messy wire though
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 16-02-2012, 06:40
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
it's a work in progress.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 16-02-2012, 08:04
jwfoss jwfoss is online now
Chasing Elegant Simplicity
AKA: Justin Foss
Looking good StuyPulse, I'll swing by and check out your robot at NYC. Fender shooters unite.
Do you guys have anymore documentation on your wheels (how you modified the AM hubs to fit the 6" pnuematic tires)? I am sure alot of teams would love to see some information on this, perhaps you can create a whitepaper.
Unread 16-02-2012, 08:38
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Terrific, StuyPulse. Good Luck and see you in NYC.
Cold Fusion's 10th Season
Unread 16-02-2012, 10:31
sammyjalex's Avatar
sammyjalex sammyjalex is offline
AKA: Sam Alexander
sammyjalex has much to be proud ofsammyjalex has much to be proud ofsammyjalex has much to be proud ofsammyjalex has much to be proud ofsammyjalex has much to be proud ofsammyjalex has much to be proud ofsammyjalex has much to be proud ofsammyjalex has much to be proud of
Great job, Stuypulse! That robot looks awesome! I can't say I'm surprised. I am always a fan of what Stuypulse puts out.
I'm very excited to see it in action at NYC! I'm especially looking forward to seeing how you implement this fender strategy - we had been considering it for a while. I hope we get some good matches together.
Great work again and see you in a few weeks!
New York City FIRST
nycfirst.org
Unread 16-02-2012, 11:29
AKA: Dripto Debroy
Team Role: Student
My throat's killing me and I'm taking the day off. I'll try to make some pictures to explain what we did.
Might also just take some pictures during our meeting tomorrow, I'm sure we have a dis-assembled wheel around as a spare.
Unread 16-02-2012, 15:39
Ninja_Bait's Avatar
AKA: Jake Potter
That is to say, we will be making spares starting tomorrow of a variety of things, so we will document the creation of the wheels.
Unread 16-02-2012, 16:24
AKA: Dripto Debroy
Team Role: Student
Oh right, I only did 8 because I thought it wouldn't work. :x
Good thing I was wrong.
