Go to Post We'll defenestrate our programmer, and I'll report back our solution if we get anything working. - Nick Seidl [more]
Unread 15-02-2012, 09:42
scaryone's Avatar
scaryone scaryone is offline
FRC #0058 (The Riot Crew)
scaryone will become famous soon enough
Polycord Slippage
Hi All
Trying to use orange polycord to drive two conveyor belts. Having the same problem we always face which is the belts slip on the pulleys once a load is applied. We are using 1/4" belts on pulleys made from 2" PVC Dowels with a channel cut for a groove. The groove is not "V" or "U" shaped. Are we using:
  • A: Wrong material for Pulley
  • B: Too small diameter Pulley
  • C: Worng shaped groove
maybe a combo thereof or something else I've not thought of.
btw (our belts are 10% smaller than the circumferance
Thanks,
Unread 15-02-2012, 09:47
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: Polycord Slippage
You'll want to try a 'V' groove. The wedging effect of the V can generate a higher friction on the belt. Also the material of the pulley has an effect. The polycord grips onto metals better than plastic.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 15-02-2012, 09:50
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
10% reduction in belt length may be too much tension and you are causing the rollers to flex and therefore bind. I would try to reduce the lengths to 3-5% reduction overall.
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
We are doing much the same thing but the rollers (usually) turn. Look at the rollers first. How difficult is it to rotate the rollers (with polycord-induced tension but w/o motors attached)? If you can't easily turn them with your hands (but they need not spin freely), the polycord will slip. Try grease, better alignment, change polycord from 10% to 5% - something will work because ours work just fine.
Good luck!
Unread 15-02-2012, 09:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
3% stretch is working ok for us. We are using 1-1/2" ABS (about 2" outside diameter) rollers that are about a foot long. We're using ball bearings in end caps to support the rollers. We don't have any grooves in them, instead we have a simply plywood "comb" above the lower roller to keep the cords in place.
Pictures of your robot would help us help you figure out what's wrong...
Unread 15-02-2012, 10:56
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
How about a picture of the "comb" Does it help rerail derailed cords?
Thanks
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 15-02-2012, 11:10
MrForbes's Avatar
AKA: Jim
Here's our comb. It doesn't allow the cords to derail, they're pretty well contained. But you have to experiment to figure out if it will work for you, it will not prevent the cords getting tangled up if for example the balls are trying real hard to push the cords sideways.
Unread 15-02-2012, 11:16
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Here is sample of ours from a past robot.
The rectangles with the diagonals are cut out to create gaps for the cords to move through. This particular one was designed to keep two bunches of cords together, not space individual cords. The final version that was use was significantly less material but this was the first iteration.
Circles are rivets to attach this to the bottom (or top) of piece spanning the run.
We usually make the comb out of hdpe or nylon.
Name:	sample polycord comb_1.png
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 15-02-2012, 11:34
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
In the past, we have used PVC pipe (1-1/4 size, which is 1-5/8 OD) and then used the couplings as cord spacers. With 3/16 cord, we had about 5/16+ spacing.
Using bearings in the ends of the rollers helps considerably. There is a lot of tension on the tubes from the belts, and having a solid rolling surface for the bolts / axles is important.
We have used a 90% belt size in the past with no issues. They are tight, but stay tight through the season.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 15-02-2012, 11:37
AdamHeard's Avatar
Lead Mentor
It's also possible the belts are too loose and aren't getting enough normal force to get enough traction.
A more likely issue is a sheave that is not stiff enough causing friction through deflection.
Unread 16-02-2012, 10:43
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
add an adjustable belt tensioner
Unread 16-02-2012, 11:17
Mark 3138 Mark 3138 is offline
Mark 3138
AKA: Mark Adkins
Mark 3138 is on a distinguished road
We had slipping last night and cleaning the cord and pulleys helped...alot. We used mineral spirits. Alcohol would probably work also.
Unread 16-02-2012, 12:06
scaryone's Avatar
I wonder if belt dressing would work
Unread 16-02-2012, 14:17
WarehouseCrew WarehouseCrew is offline
FRC #3299 (Warehouse Crew)
Team Role: Parent
WarehouseCrew is an unknown quantity at this point
Jim (Mr. Forbes), what motor and gearing is your team using to drive the polycord rollers? Are you using solid or hollow (tube) polycord? Does thickness play a big factor, We have 1/4" tube, but have yet to fabricated lifter (hopefully tonight). Thanks.
Unread 16-02-2012, 15:01
MrForbes's Avatar
AKA: Jim
This post kind of describes our system.
http://www.chiefdelphi.com/forums/sh...43&postcount=5
There is a 9 tooth sprocket on the transmission, and 22 tooth on the roller. We are using hollow 1/4" round urethane belting from McMaster-Carr.
We haven't experimented with different sizes, we just used what it appears that other successful teams have been using for several years.
