Go to Post "The secret to success is to acknowledge that you have limits, but to never acknowledge that you have reached those limits." - lady_raidan [more]
Unread 15-02-2012, 20:01
Pirate programe's Avatar
Pirate programe Pirate programe is offline
FRC #0354
Pirate programe is an unknown quantity at this point
Damping the joystick at 1
Sorry for the undescriptive name, but there's no real way to describe this with my high-school math knowledge.
We've noticed that when our robot goes at a speed, and then moves in the opposite direction at the same speed, it starts tipping over. As such, we'd like the joystick, when it is set to a certain value (let's say 1), to slowly ramp up toward that value, instead of immediately going to it.
Any ideas?
Unread 15-02-2012, 20:14
Re: Damping the joystick at 1
Any ideas?
Run your joystick commands through a rate-limit filter.
Do the LabVIEW equivalent of this:
change = joystick - limitedJoystick;
if (change>limit) change = limit;
else (if change<-limit) change = -limit;
limitedJoystick += change;
limit is the amount of change you will allow every iteration
limitedJoystick is the rate-limited joystick value you use to control your motors.
Unread 15-02-2012, 22:23
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Also, with the Jaguar v.101 firmware, you can set the speed controllers to automatically ramp up the values by simply turning the limit switch jumpers sideways. You don't need to be using CAN to do this, either, only the firmware is needed.
More information on this can be found here.
Seems a lot easier to me to just do this, if the ramp rate is good enough (I haven't tried this method yet)
I'm right 90% of the time, so why worry about the other 3%?
Unread 16-02-2012, 11:43
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Just add this VI to your Teleop loop. All you have to do is wire your joystick input (which must be between -1 and 1) to the "joystick input" side, wire the output to your motor control VI, and pick a constant for scaling. Start with 0.1 and tune it in to what you think is best.
Once you have that, repeat for the other axis and you're done!
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 16-02-2012, 12:05
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
There is a pre-built "PID" function in LabView that does exactly this. Search for "rate limit".
We are using this to keep us from stripping gears on our ball pickup if we reverse directions quickly on it.
Find a control value that works well by experimentation. For our ball pickup, a value of 45 is good. For drive control, you may want a higher number.
Unread 16-02-2012, 12:30
juchong's Avatar
Electrical Engineer
AKA: Juan Chong
Originally Posted by billbo911 View Post
There is a "PID" function in LabView that does exactly this. Search for "rate limit".
I agree, a PID block would also work well in this case. The VI that I created is essentially the Proportional (P) section of a PID block.
Unread 16-02-2012, 12:55
Could you please post a PNG? I don't have LabVIEW installed here.
I'm wondering how you get a maximum rate limiter using only a P controller, without affecting the dynamics of commands which do not exceed the desired limit.
Unread 16-02-2012, 13:12
There are several methods in this whitepaper: http://thinktank.wpi.edu/article/140, including Ether's method, a reference to the PID Output Rate Limiter, and some introduction to low pass filters.
Unread 16-02-2012, 15:41
FRC #0354
Here's that PNG.
The use of a feedback node is throwing me off a bit, but it seems pretty straightfoward...
Unread 16-02-2012, 16:10
Here's that PNG.
Thanks, but you misread my post. My post was addressed to juchong. I was asking for a PNG of the P-controller vi he attached to post#4.
What you posted is not a P controller. It's slew rate limiter; the LabVIEW equivalent of the C pseudo-code in post#2.
Unread 16-02-2012, 17:12
FRC #0354
That's exactly what it was.
Unread 16-02-2012, 19:06
OK then. For the benefit of students reading this thread, it's not the Proportional (P) section of a PID block. It's a slew rate limiter, and it's identical to the one in the WPI paper Joe linked to.
