Go to Post I bet if anyone took a look at the 118's Bill of Materials the only thing that would be on there is hard work and that's priceless. - rcmolloy [more]
Unread 16-02-2012, 11:15
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
Exclamation TOP HEAVY!!!!
We are using 6wd and an off set center wheel. we have our electronics mounted vertical because we had no where else to put them! And we are using 2Cims for our shooter which is on top. When we went to test it last night in the hallway we went half speed and it flipped nothing broke THANK GOD. Today we are going to try to fix this problem. ANY SUGGESTIONS?
Unread 16-02-2012, 11:22
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: TOP HEAVY!!!!
Are the bumpers on it? If the bumpers are mounted low to the ground, they act a bit as wheelie bars. When fully extended, our Logomotion robot would easily tip without bumpers; with bumpers, we had no difficulties whatsoever.
Disclaimer: Low bumpers may interfere with your bump-traversing abilities.
Hi!
Unread 16-02-2012, 11:28
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: TOP HEAVY!!!!
How heavy is your robot currently? If you have weight to spare, try adding a big steel plate to the bottom of your robot. If your problem is falling backwards, add it near the front.
Unread 16-02-2012, 11:30
Shaun Coon's Avatar
FRC #2487
Re: TOP HEAVY!!!!
we fall in both directions and no we dont have bumpers on but they are sitting right above the c channel so that we can go over the bump.
Unread 16-02-2012, 11:33
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: TOP HEAVY!!!!
Our robot showed signs last night that it too was a bit top heavy. It has enough torque to flip over backward just by punching the throttle.
Our first option is to move the battery to the front of the robot. That should be enough to give us the stability we need.
Unread 16-02-2012, 11:38
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Re: TOP HEAVY!!!!
If you could lower the CIMs that you have for the shooter by going to a chain drive, that would help.
Basically, you have too much stuff, too high up.
You could put ballast in the base, but that will only fix one problem (the high center of gravity). It will not address your other (mostly overlooked) problem of moment of inertia. Moment of inertia is the tendency of an object to want to keep rotating once it has started. Or in the case of your robot, keep falling over once it has started.
The best solution would be to lower the weight that you have up high.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 16-02-2012, 11:44
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: TOP HEAVY!!!!
sounds like the dropped wheel was dropped too far... usually 1/16" is a good spot.
Unread 16-02-2012, 11:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: TOP HEAVY!!!!
Originally Posted by Shaun Coon View Post
ANY SUGGESTIONS?
I suggest you post some pictures of your robot, so we can see what you might be able to change to help fix the problem.
Unread 16-02-2012, 11:59
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Re: TOP HEAVY!!!!
It's really hard to lower the CG of a full-weight, already complete robot...
If your CG isn't centered front-to-back, move weight (the battery, perhaps?) around to accommodate.
As has been suggested, if you have any weight to spare, add it as low as you can... I prefer adding "functional weight" if possible... (i.e. beef up the bottom of the frame, rather than just strapping on dead weight)
Move any heavy objects lower, where possible... the battery, an electronics board, that gearbox/motor for your elevator, etc. Consider using two lighter motors up top on your shooter... Most people are using BB550s, BB775s, or FPs for the shooter wheels - two CIMs is more power than you need.
Take off any weight you can above ~8"... Reduce fasteners, consider rivets instead of bolts, tap rather than using a nut if you can, replace heavy upper frame members with lighter ones. A lot of upper-frames are over-engineered... 80-20 or 1x1x.125" is .5 pounds per foot, twice as much as 1x1x.0625" box. PVC rollers can also be heavy... consider removing excess ones, going to smaller diameters, or at least speed-holing them in acceptable areas. Also, if you have belting for your harvester, powering only one side, putting a thin sheet of lexan on the other side.
Add weight to your bumpers, if their center is below 8" (which it has to be this year). You have 20 pounds for bumpers... consider using steel angle instead of aluminum, using more fasteners, or some such thing.
Consider shortening your entire upper assembly. Given the high-trajectory arcs, you could likely shoot from lower (~40") without worrying about your shots being blocked.
If you really can't lower it sufficiently, and can't use a retractable wheelie bar to help you, consider removing a motor/actuator from up top entirely. It's better to have limited functionality then to spend half of every match on your side!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 16-02-2012, 12:06
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: TOP HEAVY!!!!
You could always add some sort of passive appendage that acts as a wheelie bar of sorts. It'd essentially act as a pendulum when your robot tips any noticeable amount. It should help keep you from tipping.
-Dustin Benedict
Unread 16-02-2012, 12:11
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Re: TOP HEAVY!!!!
Do you have your battery mounted as low as possible? That's the heaviest single component of your robot (almost 14 pounds, about 10% of your complete robot), so it has a big contribution to CoG. We mount ours flat on a board that is mounted to the bottom of the frame. Although, we may change ours to vertical this year, to improve accessibility, since it's all the way at the back and next to the bumper.
Another option is to train your drivers not to hit the throttle too hard. This can be enforced in your software. But this is not an ideal solution; it still leaves your robot susceptible to sudden stops, impact by other robots, tilting while going over the bump or bridge, etc.
Good luck!
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 16-02-2012, 12:23
DonRotolo's Avatar
Back to humble
FRC #0832
Re: TOP HEAVY!!!!
Shaun,
This is a rookie year for you guys, right?
OK, this kind kind of thing is what someone needs to write down so that next year's team knows it. One lesson is that the electronics guys need some space, the mechanical guys need to understand that (because high-up electronics have a tendency to get hurt, and high-up weight is always bad).
Please see if you can take a photo and post it so we can offer reasonable suggestions that will work in the time we have left.
One last thing: Congratulations! Not many rookie teams have a working robot already.
Unread 16-02-2012, 12:24
Mentor, LRI, MN RPC
Re: TOP HEAVY!!!!
Now that I have some more time...
We saw in testing our robot a two nights ago that we have a similar (although not as extreme) issue - we can pop a wheelie transitioning from fill reverse to full forward. Essentially, we have too much weight in the back of the robot, and not enough in the front. We did a pretty good job of managing the height of our CG, though, so we don't actually tip over!
We weighed the robot by putting on end on blocks, and the other on a scale (may not be 100% accurate, but close enough) - we found the back weighed about 65lbs, and the front about 30lbs. We have a little more weight to add still (light weight panels, some small modifications as we see things aren't working correctly, and our bridge manipulator), but we should be able to add some nice steel plates to the front somewhere to help balance out the CG.
Unread 16-02-2012, 12:30
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: TOP HEAVY!!!!
In addition to fixing the core problem, which is a high CG, you can do some software controls to prevent the driver from accelerating too quickly. Ramping up speed changes over a second or two can really help, although make sure your drivers are aware of the impact that might have on balancing. I'm not generally a fan of putting dampeners and filters between the driver and robot, but this is sort of 'free' and can quickly tuned or turned off as needed.
If you have a gyro, you could also use that. If the gyro saw the bot tipping too much, it could either limit any further acceleration or even go in the other direction momentarily. Traversing the bridge or bump would obviously cause some issues with that, so that may just not be practical this year.
Get your CG as low as you can and consider software dampeners to control any remaining issues.
Unread 16-02-2012, 12:39
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
Re: TOP HEAVY!!!!
I would first calculate your center of gravity. Then I would play around and try to move a few things to the front. If you had a picture that would really help us.
When testing I would make a roll Cage just encase the worse happens. We learned that in 2010 when our robot completely flipped over.
Steve
-Programming Mentor
- Team 578 Alumni
