Go to Post Since you have to undo all the connections anyway in order to swap them, you might as well take advantage of the opportunity to do some simple and straightforward troubleshooting. - Alan Anderson [more]
Unread 15-02-2012, 18:05
Superechidna Superechidna is offline
FRC #4118
Superechidna is an unknown quantity at this point
Smile Jerking Motors-Wireless Issues
We have been having a problem with our Black Jaguar motors. When we move the controller forward the motors turn on and spin the wheels but whenever the motors move it is as if the signal is sporadic and constantly turning on and off. We think it might be the wireless because we connected our classmate (laptop) with an Ethernet cable straight to the C-Rio and there were no issues.
Unread 15-02-2012, 18:37
Re: Jerking Motors-Wireless Issues
A radio reset takes a full minute, so if it's cutting in and out quickly, then it isn't the radio power.
I'd suspect that the wireless is intermittent because of conflicts and collisions with other wireless networks in the area.
You can try setting the DLink to different channels to see if that clears it up.
Unread 15-02-2012, 21:20
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Another thing to check is the diagnostics tab on your driver station. Look at the error messages being generated. You may have improperly programmed your robot and the loops may be running too slowly.
Unread 16-02-2012, 00:16
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
What colors are the Jaguar LEDs turning when the motors stop moving?
You could be triggering the built in over current protection, which will shut off current if the motors are drawing too much of it.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 16-02-2012, 11:06
Derek012's Avatar
Derek012 Derek012 is offline
I miss my frisbees
FRC #4564 (Orange Chaos)
Derek012 is on a distinguished road
One issue you might have is in the program if you are using else statements and have the same motors in different ones than it will cause these sporadic readings you are talking about.
Unread 16-02-2012, 11:12
Derek012's Avatar
I miss my frisbees
yeah depending on how much CPU the rio is using
Unread 16-02-2012, 12:57
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
When one of my teams first got their drivetrain going it worked flawlessly. When they powered down the robot and switched the victors into brake mode, it powered back up and we had a similar problem as described. We powered it down and switched the victors back into coast and the problem dissappeared. Then we left the system powered on and switched back to brake mode and the problem dissapeared. We have never had a problem since. No idea what it was but this is how we fixed it?
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 16-02-2012, 13:23
bfk bfk is offline
FRC #2521
bfk is an unknown quantity at this point
We saw something similar. Turned out that the converter for the DLink was not plugged into the clean power outlet on the Power Distribution board. When the motors are running the 12 volt on the PD gets enough noise on it to cause problems with the radio.
Hope this helps.
