Go to Post FIRST is not a destination, its not the reward, its the slingshot that will launch you from where you are, to where you can be. - KenWittlief [more]
Unread 16-02-2012, 13:24
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Clamshell Comms Problems
Recently the Clam Shell has been having, communication/Sometimes Robot Code problems with the cRio. From my laptop I can deploy code just fine and even ftp the cRio over the bridge wirelessly.
When We Tether the Clam to the Bridge it works fine.
Anyone know what may be going on?????
Unread 16-02-2012, 13:34
Re: Clamshell Comms Problems
You seem to be saying it's the Classmate wireless that's at fault.
It could be as simple as a wireless conflict with other devices in the area using the same band/channel as the Classmate.
Is your programming laptop wireless using the same band and channels as the Classmate wireless?
You can test that theory using another home router.
  • Ethernet cord from the Classmate to the router
  • Common SSID and security on the router, and DLink switched to bridge mode
Unread 16-02-2012, 13:41
gixxy's Avatar
Alright. I will being going into some of these tonight. Thanks!
What I really wanted to test was if my laptops connection was going out, and it wasn't being noticed through a browser FTP. But sadly my Laptop is Linux.
Unread 19-02-2012, 14:31
gixxy's Avatar
Thank you. Changed the Bridge's Channel and everything is right as rain.
