Go to Post I hate to do say it with these words but...We're all in this together. - dellagd [more]
  #31   Spotlight this post!
Unread 04-01-2003, 20:36
Noelle Noelle is offline
#0180 (S.P.A.M.)
Noelle is on a distinguished road
Send a message via AIM to Noelle
Re: Re: how?
Originally posted by OneAngryDaisy
even though its probably impossible, use your imagination- stack the boxes so that their longer side faces up in the air-
you guys actually figured out how many extra it would be? also... wouldnt you start taking down some to make it closer to even stack to floor ratio?
SPAM rules!
  #32   Spotlight this post!
Unread 04-01-2003, 20:41
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Using my handy dandy worksheet skills, I have created a fully functional worksheet to find out the winner.
  #33   Spotlight this post!
Unread 04-01-2003, 21:04
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
You forgot to take disqualifications into account.
  #34   Spotlight this post!
Unread 04-01-2003, 21:17
Joe Matt's Avatar
If you are DQ'ed, you don't get any points. So it dosn't matter.
J/K I'll try to add that and mess around to see what works best.
  #35   Spotlight this post!
Unread 04-01-2003, 21:31
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
If Your opponent gets DQ'ed you get twice your score.
The max score is actually 1784. I have a spread sheet that simulated every different arrangement and 1784 comes when you have 21 stack 24 unstacked and again with 23 stacked and 22 unstacked.
I'm pretty sure that my math is right. I don't think earlier posts were too accurate as far as the final score. This will hopefully settle this. Note: this includes getting points for all four robots on the ramp. However, with only two 1684 becomes the high and with the same arrangements.
  #36   Spotlight this post!
Unread 04-01-2003, 22:10
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Re: how?
That is very unlikely (re: impossible) because of the shape of the containers, they have a tapered end. They are molded after all, and in order for you to stack them end to end you would have to stack them the long way, but have the lid side and the non lid side be opposed all the way up. For example, first one lid facing right, 2nd lid facing left, 3rd right and so on. But you would still get the angle from the bottom one resting on that tapered angle unless you would lean it against something. It might be possible to stack one or two, but no more unless you interact with the stack which is a no-no!
I think that only one container will be put on it's side in a stack, and that will have to be the one on top as demonstrated at Kickoff.
Oh and if someone does happen to stack 23 containers on top of each other, this would result in a stack that is over 30 feet tall. 30.1875 ft. to be exact or 362 1/4 inches
I hope our competition venues have tall ceilings!!!!!
  #37   Spotlight this post!
Unread 04-01-2003, 22:12
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
While it is physically impossible, it would still be the highest score. Because this can't ever be met, we may have to wait until competitions to get a more reasonable estimate of what is high.
  #38   Spotlight this post!
Unread 04-01-2003, 22:26
#0180 (S.P.A.M.)
your doing that with one allience getting DQ'ed right? then the two robots of the QD's team wouldnt count in witch would make the 1648 the right one. BUT i dont see how 2(21x24+50)= 1684 check your math maybe? its actually 1108.... and even with your calculations you dont have the top one tilted... 23 (22 stack) times 23 laying on the ground........
SPAM rules!
  #39   Spotlight this post!
Unread 04-01-2003, 22:30
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
You're not thinking out of the box. If each contaner was stacked length to length you'd have 24.25"*#ofbinsstacked/15.75"
15.75" is the hieght of one bin in it normal orientation. 24.25" is how long it is.
With 21 stacked the actual hieght would be 33 boxes.
With 24 it's 36 high
  #40   Spotlight this post!
Unread 04-01-2003, 23:10
#0180 (S.P.A.M.)
sorry didnt realize you meant to have them stacked that way, but still 22 and 23 isnt the highest?
SPAM rules!
  #41   Spotlight this post!
Unread 04-01-2003, 23:14
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
It is impossible to ever get the maximum number of points, simply because it would be impossible to reach high enough to stack 22 boxes. Also, who really thinks that 22 will stack without tipping? I dont...
Cory
2001-2004: Team 100
2006-Present: Team 254
  #42   Spotlight this post!
Unread 04-01-2003, 23:18
Joe Matt's Avatar
Update
  #43   Spotlight this post!
Unread 04-01-2003, 23:37
Dinush Dinush is offline
Build Team!!
AKA: Dina Begun
#0912 (Iron Lyons)
Team Role: Student
Dinush is an unknown quantity at this point
Send a message via ICQ to Dinush Send a message via MSN to Dinush
wouldn't it be nice to stack them so that one box is right side up, second box is bottom side up, third is right side up, etc? they won't 'nest' that way, so I think every two boxes will count in hight as three? I'm not sure really about the height- i'm a metric person and really can't calculate in your imperial system.
--> 2003: Winners of Canadian Regional. Thanks 1088 and 378!
  #44   Spotlight this post!
Unread 05-01-2003, 01:25
Cory's Avatar
AKA: Cory McBride
This does not just apply to you, but to everyone talkign about DQ's. Keep in mind:
"In the qualification matches, if a referee disqualifies a team, only that team is disqualified." The Game, 9.6
So..... you can never even get 1000 points, except for in the finals, where you would never ever be able to keep a stack of 23 bins together
Cory
2001-2004: Team 100
  #45   Spotlight this post!
Unread 05-01-2003, 01:28
Mike537Strategy Mike537Strategy is offline
#0537 (Charger Robotics)
Mike537Strategy is an unknown quantity at this point
I don't think you people would really need this, but using the 22 stack and 23 boxes rule I found the ratio for most points...
1:1.41 (stack:boxes in score zone)
that is a more real-world idea because no team is going to get a stack of more than 15 anyway...it would take way too much time, especially if you don't have any defense around the stack.
"Charging into the future, one game at a time." - Team 537 motto
Fantasy Football! EddieMcD Chit-Chat 176 30-12-2003 18:30
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
Chamionship Qualification - feedback needed ASAP! dlavery General Forum 97 11-10-2003 07:17
Seeding Calculations archiver 2000 50 23-06-2002 21:57
