Go to Post Checklist: Robot on, thinkamajig set, autonomous set, safety bar pulled. - DonRotolo [more]
Unread 16-02-2012, 17:32
Team1605 Team1605 is offline
FRC #1605
Team1605 is an unknown quantity at this point
Problems with Deploying code on crio from windriver
Can't deploy code to crio from windriver. crio is imaged, i'm getting a license error
Unread 16-02-2012, 19:20
msulaimain's Avatar
msulaimain msulaimain is offline
AKA: Muhammad Sulaiman
FRC #3346 ([{Kamikaze Komets}])
msulaimain can only hope to improve
Send a message via AIM to msulaimain Send a message via Yahoo to msulaimain
Re: Problems with Deploying code on crio from windriver
In your Windriver installation disk there is a file that is your license. You have to copy and paste that into your program file---Windriver folder. Your not licensed and that is why your getting that error. You also want to check if your team number is set under Preferences in Windriver. After you click preferences go to FIRST Downloader and put in your team number and browse for the built .out file which should be in your Workspace folder. Just follow directions in this pdf: http://firstforge.wpi.edu/sf/docman/...tation/doc1197
This pdf has everything that you need. Just make sure you installed Windriver correctly. Then follow the downloading to robot instructions as well.
int main()
::::::::: include=>commitment;
::::::::: int=>school name=>Asheboro::High
::::::::: int=>team name=>Kamikaze::Komets;
::::::::: Priority_Queue=>FRC Championship::2012;
::::::::: Max_Element=>Teamwork;
