Go to Post To me, every robot is a moving mechanical art form, a sculpture made of aluminum, motors and gears, and I think that soon we will be seeing those art forms involved in some of the most fantastic robotic "dances" that any of us have ever seen - DougHogg [more]
Unread 16-02-2012, 18:03
jeremy5561 jeremy5561 is offline
FRC #0919
jeremy5561 is an unknown quantity at this point
Cannot drive robot
I've reimaged the robot and deployed the default FRC project but I can't drive it. I get error 44003 or something like that, I can't remember. Is it because the camera isn't connected.
Does the camera need to be connected or can it just be disabled?
Unread 16-02-2012, 18:16
Re: Cannot drive robot
The camera doesn't have anything to do with it.
Unread 16-02-2012, 21:46
The exact error message would help narrow down what's wrong.
In the meantime, do you have the cRIO modules in the proper slots? Slot 1 must have an analog module, slot 2 must have a digital module, and slot 3 can have a solenoid module if you want one. (What you can do with the remaining slots depends on whether you have 4 or 8 slots total.)
Unread 17-02-2012, 12:12
FRC #0919
I figured out the problem, it was an improper jumper on the digital sidecar. We're reassembling the jaguars.
We have two motors each side for a total of 4.
Are we supposed to connect PWM 1 and 3 to left and 2 and 4 to right because only one side is moving. When teleoperated mode is enabled, all motors are solid yellow.
Unread 17-02-2012, 15:44
The default code only enables PWM 1 & 2.
You can use "Y" PWM cables to split a signal to both Jaguars on a side.
You can also change the code to be whichever PWMs you like.
Unread 17-02-2012, 20:07
FRC #0919
Do you have any idea how to get that to work by programming in LabView. I've been poking around for hours and KIND of get it.
I'm looking at the TeleOp block diagram and I see Click image for larger version
ID:	11958. I'm thinking the RefNum set sets the motors that are to be operated by the Arcade Drive thing. The RefNum set thing opens this Click image for larger version
ID:	11959 control panel. I see motor[], which i'm guessing is the array of motors that the thing is supposed to set.
I'm working on the robot tomorrow and don't have the CRIO at the moment but I remember that the left motor was set to INVERT so i'm guessing all you need to do is INVERT all the left motors.
Does anyone know how to add additional motors into the array. If any team has done this I'd appreciate any help. Stop build day is looming, this is almost the last day and I have a tremendous amount of homework.
Unread 17-02-2012, 20:50
The motors/PWMs are all defined in Begin.vi
That's were you'd add motors or change PWMs.
That's where the Refnum gets created.
Unread 17-02-2012, 21:04
FRC #0919
Thank you very much i've been looking for that for hours.
