Go to Post If Will uses the word "dope", doesn't wear a larger FIRST logo, takes up half of the St. Louis arena, if there was not enough seating in the pits, if the music was killed during finals, it was all justified tonight. - Barry Bonzack [more]
Unread 16-02-2012, 19:27
oswaldonfire's Avatar
oswaldonfire oswaldonfire is offline
Chris Marion
FRC #3142 (Aperture)
oswaldonfire is an unknown quantity at this point
Re: Team 3142: Week 5 preview
We have a mini-ITX computer running onboard; it has an Atom dual-core 1.8GHz processor, 2GB RAM, a 4GB SSD, and power regulating and supply equipment to allow it to run on anywhere from 6-34vDC (this circuitry also powers the Kinect). We're all in love with it - it's small, around six inches square, and draws maybe 30 watts and gets slightly warm while doing all its image processing.
Right now we're running into framerate issues while processing both feeds - getting only around 6fps from the Kinect and 12 at best from the other camera.. although I attribute this to the fact that we like our nice high resolutions too much - today we'll try moving down from 640x480 and we should see a huge gain in performance. Although the smaller the resolution from the Kinect, the less resolution our distance readings will have. Right now we have a reliable resolution of around 2-3 inches, which is acceptable.
I should also note that we're running the excellent RoboRealm software on the computer to do our vision processing - it's an amazingly powerful, GUI-based machine vision platform, and RoboRealm is giving free copies to any FIRST team who is interested (it's normally $50) - if nothing else, your team should grab a copy to play around with in the off-season.
I've found that it's a great tool for teaching the basics of machine vision, and its easy enough to learn the basics to get students who otherwise wouldn't step foot near C++ excited about programming and computers. I worked with two freshmen on our team to develop the Kinect targeting software, and both had no previous experience in programming. There is also plenty of room for the experienced programmer - RoboRealm has a full-featured API, built-in HTTP and FTP servers, and you can write custom image processing modules and plugins in C, Python, or Visual Basic. Check it out - http://www.roborealm.com/
I should also note that we were about 8 pounds overweight as it appeared in the original photo; the kids have since re-designed the robot to weigh less while simultaneously taking 8 inches off of its height to help with the center of gravity. I personally feel that there were much better ways to go about reducing the weight and CG, because now our robot can only hold two balls, and three in a pinch. The students feel that we can make up for this limitation with our shooting accuracy, however.
