Go to Post "I need the adjustable hammer" "You mean that wren-" "No, it's a hammer" - Karibou [more]
Unread 16-02-2012, 19:01
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Honeywell Microswitch
How do I wire a honeywell microswitch so it shows up on the ds?
Unread 16-02-2012, 19:03
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Honeywell Microswitch
Are you talking about wiring it to the driver station through the cypress board? Or are you talking about wiring it to the digital sidecar and have code to read it and display its state to one of the LEDs on the cypress module? Please specify more details.
Unread 16-02-2012, 19:55
dmitch's Avatar
I need to have it on the robot wired thru the digital sidecar.
Unread 16-02-2012, 20:07
mikets's Avatar
Software Engineer
Wire the microswitch with the NO (Normal Open) and Common to one of the digital channel's SIG and GND. Then you read the corresponding digital input channel in your code (don't know what language you are using). If you want the state to show up in your driver's station, you need to explain what exactly that means. Showing up in the dsLCD?
Unread 16-02-2012, 20:50
dmitch's Avatar
In the top window of the driver station there are different "lights" for the various analog and digital inputs. I just need the D I/O 1 light to lit up when the microswitch wired to D I/O 1 is pushed.
Unread 16-02-2012, 20:54
You didn't answer the very important language question. If the answer is LabVIEW, wire it as described above and then see this WPILib Tracker bug:
http://firstforge.wpi.edu/sf/go/artf...3294436055 44
Unread 16-02-2012, 23:48
dmitch's Avatar
I am using C++. I moved this to the programming forum since the wiring question was answered a while back.
http://www.chiefdelphi.com/forums/sh...d.php?t=103041
