Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. But crazy ideas tend to produce some excellent results. - Yipyapper [more]
Unread 14-02-2012, 14:17
Ross3098's Avatar
Ross3098 Ross3098 is offline
Programmer
AKA: Colin Ross
FRC #3098 (The Captains)
Ross3098 will become famous soon enoughRoss3098 will become famous soon enough
Problem processing images on the Dashboard
After looking around Chief Delphi I still have not found an answer to the problem that we are facing at the moment. Our vision processing code is working when on the cRIO 100% (other than making the robot lag terribly).
After porting most of our stuff over to the dashboard so that it is processed there, we have observed the results on the Driver Station. Our direct camera feed works, no problem. Our filtered feed, shows a plain white image to the DriverStation. Its not empty like it is getting no image, it is white as in a blank image. We are displaying filtered feed right after the color threshold for debugging. The direct camera feed (the working feed) is sent to the color threshold and after going through the threshold, it is white.
I will try and post a picture of the snippet that returns the blank image.
Any Ideas?
2012 FRC Championship: 4th pick, Quarterfinalist: Thanks 1507, 51!
2012 Michigan State Championship: 4th Seed, 3rd Alliance Captain, Semifinalist: Thanks 33 and 2137!
2012 Northville District: 3rd Pick, Quarterfinalist. Thanks 302, 4405!
2012 Waterford District: 2nd Pick, Finalist. Thanks 573, 3601!
2011 Waterford District: 8th seed, 1st pick, Semi Finalist. Thanks to 573 and 3770
2011 Ann Arbor District: 2nd seed, Finalist. Thanks to 548 and 247.
2011 Michigan State Championship: Semi Finalist. Thanks to 548 (Again) and 74.
2011 FIRST World Championship: 8th seed, Quarterfinalist. Thanks to 74(Again) and 846.
Unread 14-02-2012, 18:11
Ross3098's Avatar
Programmer
AKA: Colin Ross
Re: Problem processing images on the Dashboard
Anyone?
Kind of dead in the water at the moment D:.
Unread 14-02-2012, 21:25
I haven't seen this before. The filter is a threshold, right? If it is white, you are possibly displaying with the wrong color palette, or perhaps you wired up the value to replace with in the threshold? Since this is a LV dashboard, it should be pretty easy to debug. Probe the images a step at a time and follow it across the diagram.
Greg McKaskle
Unread 16-02-2012, 09:04
Ross3098's Avatar
Programmer
AKA: Colin Ross
We have tried to deploy it and it immediately closes with the error:
Image not large enough.
Color Threshold Failed.
A more accurate representation of our diagram would be this: (No screenshot sorry)
10.30.98.11 -> Read MJPG -> Color Threshold ->......
Again, we are using the Read MJPG vi connected to the camera ip address and having the IMAQ image that we attached to to Camera Image go into the Color Threshold Vi. The Color Threshold has all of the appropriate inputs and outputs connected (Color Mode, and Ranges).
We do not know what this means. We have tried all resolution sizes and settings for the camera.
Unread 16-02-2012, 20:44
I haven't seen this myself, so I can only give you a few things to check. Make sure that you have an Image Create wired to the Get Image and another created and wired to the threshold.
Greg McKaskle
