Go to Post Don't let my students know I skimmed that blog and didn't read it thoroughly. - rlance [more]
Unread 16-02-2012, 16:28
hannigan hannigan is offline
FRC #2264
hannigan is an unknown quantity at this point
CAN timeout
Hi,
This is our first year using CAN (serial connection, not 2CAN yet) for connecting our Jaguars, and we have been having some trouble with timeout. We were able to daisy chain any 5 jaguars together, but when we get to the 6th one, the code says that the jaguar timed out.
We tried different cables, and we tested all of the jaguars in this 5 jaguar chain and they all worked. Is there a limit to the number of jaguars we can have in the CAN daisy chain? Has anybody else had this problem?
Thanks
Unread 16-02-2012, 16:42
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
Re: CAN timeout
You are well below the limit. We have had this issue if we miss number any of the Jaguars.
I would check/ renumber the Jags and verify the code is also correct.
Unread 16-02-2012, 16:43
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: CAN timeout
also, verify you have the terminators (100-ohm resistors between the middle two pins) on both sides of the CAN bus.
Unread 16-02-2012, 17:27
FRC #2264
Re: CAN timeout
Thanks, I double checked it and it seems to be wired correctly. In the db9 connection to the crio, I have the resistor connected between the red and green wire. For the terminator at the end of the daisy chain, I have a rj11 connector with a resistor in the middle two contacts. Is there anything else that I may be looking over?
Thanks
Unread 16-02-2012, 17:41
Mentor, LRI, MN RPC
Re: CAN timeout
I just noticed your local here in MN... Any chance you guys are going to the pre-ship scrimmage at Simley on Saturday? We have a couple of students who are experts on CAN (we ran 7 Jags last year with it) who could help out there!
Unread 16-02-2012, 18:05
FRC #2264
Re: CAN timeout
Yes we are! That would be great. We are Inceptus team 2264, I am Emily, the electrical manager. I will stop by your pit on Saturday.
Unread 16-02-2012, 23:44
Mentor, LRI, MN RPC
Re: CAN timeout
Awesome! We'll make sure to hook you up with our programmers, and we can double check all of the wires and connectors to make sure its not an electrical problem. We'll see you there!
Unread 17-02-2012, 00:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: CAN timeout
I would look at this end very carefully. If you've actually crimped the two bare wires on a resistor in an RJ11 connector, this could be your problem. Or a problem, anyways. Someone tried that on our team, and the bare wires were so close together they ended up making intermittent contact. That would short the data pins together with predictably bad results for the network.
Also, the CAN network is limited to a total length of 20 feet. If you have a bunch of 4 foot CAN cables for some reason, that last jaguar could be pushing you over the maximum length.
Unread 17-02-2012, 10:08
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
Re: CAN timeout
One of the problems we have is our first black jag, the pins on the serial side are not bent out enough, so we have to bend the connector on to the pins by pulling the cable back and zip tieing' it somewhere. Try holding the cable bent right at the connector and try loading code, try again in the other direction. You could also try a piece of plastic or a screwdriver in between the clip and the connector housing.
"No, you can't use the Kinect to do pelvic thrusts."
Unread 17-02-2012, 13:00
How many messages are you sending/receiving per second?
