Go to Post Maybe FRC WILL casue world peace, who knows, eh ? - Tottanka [more]
Unread 17-02-2012, 01:04
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Need Help with Big Sprocket
Hi, we tried quite a few things and we are out of ideas. We have a very big sprocket to rotate the turret on a turntable. It is McMaster Carr part # 18635A52. The sprocket came out to be 250 teeth. The CAD model was generated in Inventor. The sprocket was made using waterjet and is 0.090 inch thick. The problem is the #25 chain cannot wrap around it. It seems the pitch of the sprocket is slightly under 0.25 inches. After about 50 teeth, the chain does not want to seat in the sprocket anymore. For most normal size sprockets this would not be a problem because it will only engage 40 teeth or so at the most. Our chain will need to engage about 150 teeth.
Does anybody have experience in making such large sprockets? Did you experience these type of problems? Please help. I have attached the CAD model.
Please don't call me Mr. Ed, I am not a talking horse.
Unread 17-02-2012, 01:10
nitneylion452's Avatar
AKA: Joe Lee
Re: Need Help with Big Sprocket
Why not try the attachment system FRC 95 is using?
http://www.chiefdelphi.com/forums/sh...ghlight=turret
You're probably going to have problems with a sprocket that size.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 17-02-2012, 01:14
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
It's difficult for roller chain to stay on pitch over long distances of continuous tooth engagement, as slight tolerance variations can really add up. Generally using sprockets with more than 100-120 teeth should be avoided because of this.
One way to get around this tolerance limitation of large sprockets that do not have to rotate continuously is to use a toothless sprocket and physically lock the roller chain to some point on the sprocket; torque is transmitted through a combination of friction and the locked position.
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-02-2012, 02:18
Lee Reed Lee Reed is offline
FRC #2620
Lee Reed is an unknown quantity at this point
I'm going to guess you want to do 360 + rotation & don't want to fasten the chain to it but want to keep on revolving. That being said, if I was faced with your problem I would apply a wire wheel to the teeth at frequent intervals to "eat away" the excess tooth width. Don't agonize about the tooth geometry it doesn't have to be perfect it just has to work.
Good luck. Regards.
Unread 17-02-2012, 02:37
Ed Law's Avatar
Good luck. Regards.
Yes we do not want to be limited too much on amount of rotation. Another reason is having most of the chain engaged in the teeth will ease my concern about the chain drooping down.
What is wire wheel? Is it just wrapping wires around the chain? Do you have a picture?
Unread 17-02-2012, 03:10
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
I suggest you consider "segmenting" your sprocket.
Lets say you plan to divide it into six pieces, and you know the saw cuts will allow the segments to collapse inward just enough to get the rollers back down into the roots of the teeth.
You lay out your six slice lines and you mark out three mount holes per segment to be drilled through each segment and through whatever the sprocket mounts to. You drill your mount holes BEFORE you slice up the sprocket into segments.
Now by slightly oversizing the three through holes in each segment, relative to the mounting fastener OD, you can shift the segment locations radially, thus shrinking the effective sprocket diameter enough to maintain decent chain wrap engagement across all the segments throughout the full circle.
I would use shoulder screws for mounting the sprocket segments and an adjustable reamer to gradually increase the sprocket mount holes' size until your chain seats fully into all six of the segment arcs (well, only three at a time really).
-Dick Ledford
Unread 17-02-2012, 04:10
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Because you have such a large contact area you could probably get away with removing or shortening some of the teeth this will turn it into a many sided polygon with a perimeter less than that of a circle, that is if the chain is too short. If the chain is too long, then you could paint or powder coat it several times to increase its diameter.
Unread 17-02-2012, 12:31
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Could you use a pair of idler sprockets to route the chain path away from the large sprocket after some reasonable number of teeth have been engaged?
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 17-02-2012, 12:54
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
I recently used the iSprocket tool from www.firstcadlibrary.com to generate a 140 tooth sprocket by waterjet from .090" aluminum....full wrap with no issues.
I had to open the table that drives the sprocket to add a new column for 140 teeth.....might do the trick for you too.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 17-02-2012, 13:19
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Here is what I would do: I would abandon the chain idea and try to drive the sprocket like it was a gear. Take a small segment of #25 chain and then wrap it around a flanged hub of some sort, securing the ends to the flange of the hub with a pair of pins. Basically, this provides you with a "pinion gear" to install on your drive motor and power your "sprocket gear". You mentioned the #25 chain engages the sprocket fine in small intervals so driving it like a gear would only mean you are contacting the sprocket along two or three teeth.
Generating an accurate CAD model for something like this is always a pain in the @$$. Last year it took us about 15 tries to finally produce a working sprocket for our drivetrain despite using the FIRST CAD library. I assume that at this stage of the game the chances of you getting a new sprocket cut in time is slim to nil.
A wire wheel is a disc that you would install on a pedestal grinder that looks like this: http://www.wolfcraft.us/images/photo...eWheel-8In.jpg
It is used for cleaning up parts and removing small amounts of material. I remember trying this last year when my team was trying to produce their own sprockets and if you are off by much it won't work and I wouldnt suggest it.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 17-02-2012, 14:21
Ed Law's Avatar
Thank you to all your suggestions. All of them are possible solutions. Based on the amount of time left, this is what I am going to do. Jim Zondag came to the rescue again with this idea. It is similar to what Wayne suggested. I have a motor attached to the driving sprocket at one corner to turn the big sprocket. I am going to put an idler sprocket on the opposite corner to pull the chain out to reduce and split the number of teeth engaged into less than half of what it used to be. I will also mount this idler sprocket on something that has a slot for adjustment until the chain sits properly on both sides. This seems so simple and elegant. I learn something new every day.
