Go to Post If there are no top tier teams, then who do we look up to for inspiration? - artdutra04 [more]
Unread 17-02-2012, 01:53
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
2495's Shootin
http://www.youtube.com/watch?v=mqLKh0_TgSY
The first couple of clips are shooting while we were tweaking it, so their not that great. At around 1:30 is where we have our final configuration. This is shooting from 12ft away, about the distance for the key. Nowhere near what I've seen other teams in distance, but hey what can you do.
What do ya think?
EDIT: Worth noting, this wasn't aimed via our programming and we were just connecting the battery straight to it, so we didn't have speed control.
Unread 17-02-2012, 03:16
Dale(294engr]'s Avatar
Dale(294engr] Dale(294engr] is offline
Mentor/Sponsor since '98
Dale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of light
Re: 2495's Shootin
SAFETY FIRST!!! Please!! Never ever power motor directly from battery without a fuse or circuit breaker!
Breaker/Fuse is essential 1st line of safety. Especially in quickie tests
2nd line:Anderson disconnect but actively requires someone to act fast and not be entangled in the emergency such as clothes, finger binding in a chain /gear, etc
Simple enough to wire a 40A circuit breaker in series with a motor lead!!
(<<40A preferred for greatest safety margin,
selected per application
start w/20A,
ease up to 30A or 40A as needed)
Preferred is lever action circuit breaker to act as switch in lieu of plug / unplug clunky Anderson connectors as shown in video.
FYI:
Circuit Breakers are designed to HOLD at marked amperage. They break / open starting at ~125% of rating depending on amplitude & duration of over current
so 40A starts opening at 1.25*40 = 50A (cycling starts or fixed type trips)
Do view mfr CB data sheet curves detailing this dynamic!
Safety FIRST!! not an option!
FACT: when you disconnect CIM running at full speed the voltage at the separating ends rises abruptly reaching thousands of volts??
causing a visible arc!! due to the motor inductance..
former energized field collapses/cuts through copper windings, inducing a high voltage limited only by load (Vpk=dI/dT) theoretically goes to infinity!!
but practically limited by arc over at opened conductors or insulation breakdown to less than infinity!!
Check it out: use oscilloscope to view voltage peak with suitable scope probe 100 Megohm suggested 1000 Mohm better so as not damage sensitive scope input placed across motor side leads and to minimize load to see actual Vpk minimal load burden.
(lower measurement probe resistance loading decreases observed Vpk,
broadens attenuates observed impulse duration but brighter viewed on scope screen,
relative to objective to measure unloaded open circuit peak voltage)
If a human is in close proximity or in contact with i.e. holding both motor leads when motor power is interrupted,
the inductive kickback energy will cause a very memorable shock experience!!
(Human becomes motor load resistance and need only be in close proximity to leads
say .1" as inductive kickback voltage rises high enough to jump/arc to conductive skin!)
Jaguars & Victors have special internal protection devices to handle steer / recover this energy,
else output FETs suffer catastrophic punch thru, smoking them
in spite of best design punch thru still occurs albeit less frequent but dramatically as
smoke clouds rise from robot motor controllers in competition every year!
Unread 17-02-2012, 03:30
AKA: Brandon Liatys
Re: 2495's Shootin
start w/20A,
FYI:
All the alligator clips were electrical taped, and we used the quick connect so we didn't have to directly touch any wires when doing this. And they were FP motors, nowhere near as many turns as a CIM. Thank you for concern though, it is something to keep in mind.
Unread 17-02-2012, 04:28
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
Re: 2495's Shootin
start w/20A,
FYI:
l
l
l
I think with some toning you'll get it. Nice robot!
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 17-02-2012, 13:47
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
Re: 2495's Shootin
your chain. it is loose....
cole?
