Go to Post As we were lying the robot down to work on it "CAD me like one of your french robots" - 1uan [more]
Unread 17-02-2012, 03:49
Shalti3835 Shalti3835 is offline
FRC #3835
Shalti3835 is an unknown quantity at this point
Jaguars aren't responding with RobotDrive.
Hi we are team 3835 and we have a pretty serious problem.
We have 6 jaguars hooked up to 4 cim motors and 2 smaller motors.
The problem is that it seems we cannot define more then 4 jaguars
in the Begin.vi file and when we try to define them, NONE of the jaguars respond (blinking in orange light)
we defined 4 jaguars and it worked but when we added the the 5th jaguar
it seems that none of them work.
Here are some things we checked:
-pwm's cable are connected ok
-teleop is ok
-battery is full
-all cables are connected good and are in a good condition
-we have connection with the robot.
Unread 17-02-2012, 07:45
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Re: Jaguars aren't responding with RobotDrive.
why are you initializing jaguars? Just initialize the motors
Unread 17-02-2012, 08:31
Four PWM outputs work. Five do not. That's a common symptom this year. Have you double-checked your Digital Sidecar to make sure it has a solid 12 volt power input? Are all three of its power LEDs (BAT, 6V, 5V) brightly lit? Describe what the Robot Signal Light is doing when the robot is working, and when it is not.
