Go to Post Wow, that is awfully impressive! How can a guy in the WWF be so smart? Oh, it's LIKE the WWF...:p - DonRotolo [more]
Unread 16-02-2012, 14:28
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
pic: Team 192's 2012 Gearbox
Unread 16-02-2012, 14:29
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: pic: Team 192's 2012 Gearbox
Great photo, what is this gear box for?
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 16-02-2012, 14:33
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
my guess: shooter err... I mean drivetrain! ;-)
gotta love the edit feature.
Unread 16-02-2012, 14:36
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I'm sure it is for their drivetrain and they are wanting some resistance to backdriving (depending on the efficiency of the worm gears). Also looks like it is for a wcd of sorts.
Mentor 2415
Unread 16-02-2012, 14:37
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
I would say drive train.
Unread 16-02-2012, 15:04
ttldomination's Avatar
Sunny
Nice render, oh wait...
Is that red delrin? Or just a really flat red paint on Aluminum?
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 16-02-2012, 15:08
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
- Sunny G.
It's all bead blasted and anodized aluminum. The shaft is steel, and the bottom dust shield is 5052.
Unread 16-02-2012, 15:13
Robotics Engineer
Assuming your worm reduction isn't backdriveable, how does the drive train react when you try to stop fast? The nature of worm gears to be non-backdriveable would make your robot very difficult to push, but also makes it so that you can't coast to a stop.
Do you "coast" via software? Or did you determine that you won't snap any gear teeth off?
Unread 16-02-2012, 16:43
Joey Milia's Avatar
FRC #0192 (GRT)
Yes this Gearbox is for our drive train
and
Yes it is for a WCD
The worm is a high efficiency 4 start gear. It is backdriveable, albeit with higher resistance than a spur gear gearbox. If they were not backdriveable, we would not be using them due to risk of the worm gear teeth shearing when we get hit.
The purpose of this gearbox is not to make it hard to push, but to make it small and have the cim's parallel to the sides of our frame.
On an off season prototype, we had victors set to brake mode and it worked really well. However, we have set the victors to coast not because of the gearbox, but because of weight distribution in the rest of the robot.
Unread 16-02-2012, 21:49
Sb28000's Avatar
Sb28000 Sb28000 is offline
FRC #2656 (Quasics)
Sb28000 is on a distinguished road
That's a really intriguing design, nice work guys. I was wondering to myself if anyone had ever oriented their CIMs on another side of their gearbox other than directly across from the output shaft (I was thinking about putting them on the same side as the output shaft, just as an idea to maybe save space and work on as a CAD challenge). But that's a really cool solution to the challenge of saving space on the bot.
Pittsburgh Regional Finalists 2010
Hoping to come back strong in 2012!
Unread 16-02-2012, 22:32
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Wow that's really sweet, congrats!
Unread 16-02-2012, 23:47
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
That's amazing. Nice job!
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 16-02-2012, 23:57
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Would i be able to get a CAD model of this? I'm guessing you have one considering its so nice. I have no intention of stealing your design or anything, just want to look at how it was made and such. More pictures would work too, but i would rather have the CAD.
Thanks
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 17-02-2012, 02:38
Lee Reed Lee Reed is offline
FRC #2620
Lee Reed is an unknown quantity at this point
This is a beautiful gearbox. An idea worth stealing for next year. By the way how did you hob the worm wheel?
Unread 17-02-2012, 05:27
Joey Milia's Avatar
FRC #0192 (GRT)
Thank you all for your praise
Thanks
My intention is to publish the CAD model of the gearbox on FRC designs sometime soon after build.
I will also be releasing a write up about the design process as well as the choices I made and the reasoning behind them.
Another note on the Gearbox. It was originally designed in the spring/summer of last year and two prototypes were made in the fall. It was then refined and modified for the 2012 FRC season.
I did all of the design work on it and everything but the dust shield was manufactured by myself or other fellow students on our team, a large portion of which was done on our CNC mill.
If you mean how did we cut the worm gear the answer is we didn't. Both the worm and worm gear were purchased from Motion Industries but they are also available from sdp-si.
