Go to Post Nutritionally speaking I didn't get enough (MOE) green in my FIRST diet this year! - Mark McLeod [more]
Unread 17-02-2012, 02:33
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Out of 40amp slots
So I've run into quite a funky problem that I've never seen before. Heres a list of motors and what their used for on our robot:
2 Banebots (conveyor)
2 FP (shooter)
4 CIMs (drive)
4+4=8, the exact number of the 40amp slots on the P/D board.
Problem is, were missing our bridge manipulator which is most likely two window motors. And I'd like to put those in the 40amp, as they need the power. Would anyone recommend putting a victor/jag into a 30amp for something like a conveyor belt?? It seems like it should be fine, but I thought I'd check.
Unread 17-02-2012, 02:43
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Out of 40amp slots
The circuit breaker does not define how much power the device uses, it only limits the maximum that can flow through the circuit to protect the wiring. I've never seen any window motors that need more than 30 amps in their native environment so they should be fine on a 30 amp breaker.
Unread 17-02-2012, 08:26
Isaac501 Isaac501 is offline
FRC #0501 (The PowerKnights)
Rookie Year: 1995
Isaac501 is just really niceIsaac501 is just really niceIsaac501 is just really niceIsaac501 is just really nice
Check motor curves, determine expected load and design around them.
You're doing it wrong.
Team 501 Academic Advisor, Systems Build Mentor
Unread 17-02-2012, 08:38
Brandon,
The window motors actually draw about 20 amps at stall. (one slightly higher and the other slightly lower.) Collin you were looking at max power not current I think.
It is important to remind everyone that with increased motor usage, available electrical power from the battery will become an issue. You cannot simply run all the motors at the same time. The terminal voltage on the battery will fall to the point that the Crio either disables all outputs or it reboots. Be careful to watch terminal voltage as displayed on your dashboard while practicing. Expect that transients are much worse than what is displayed on the dashboard.
Unread 17-02-2012, 10:17
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We're only using 4 of the 40 amp breakers....we're running our shooter and harvester FP motors on 20 amp breakers. It seems to work just fine, too.
Unread 17-02-2012, 11:33
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
we have never used the 40 amp breakers for anything except Cims also we usually use 30s for window and 20s for Banebots.
Expect the best, Prepare for the worst
Unread 17-02-2012, 23:12
Trez's Avatar
Trez Trez is offline
FRC #3606
Trez is an unknown quantity at this point
Brandon,
What is usually the bear minimum volatge that the cRIO or the wireless router starts to reset? Is it like 10 volts?
Prototype, Prototype, Prototype
Unread 17-02-2012, 23:14
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Brandon,
Quoted this just so it's read again.
There's no reason to run the windows on anything but a 20A breaker.
-Dustin Benedict
Unread 17-02-2012, 23:31
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
It's well below that. The reason teams are required to wire the cRIO and the bridge into the dedicated power terminals at the end of the PDB isn't because FIRST likes to make random rules. These power terminals have been designed so that your cRIO and bridge will continue functioning well after the rest of the robot is starved for power.
The cRIO-II operates down to 9V although its nominal power supply on the PDB is 24V. The original cRIO operated down to 19V, and would cut out when battery voltage dipped to 8V.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 17-02-2012, 23:34
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The wireless router and the cRIO supply both have boosters designed to ensure no loss of connectivity. The supplies stop working at about 5 volts, based on what others have said. I don't know the actual specifics for the D-Link, but the 8 slot cRIO needs 19 volts to function and the 4 slot cRIO needs 9 volts to function.
Unread 19-02-2012, 00:50
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
2 FP (shooter)
4 CIMs (drive)
The Banebots and Fisher Price motors are both fine at 20 or 30 amps, so they can be moved down. I don't think the window motors need 40 amps, either.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 19-02-2012, 01:54
Can you post up if you have any issues with the shooter FP motors on 20 amps? I'm just curious.
Unread 20-02-2012, 08:29
Trez,
The power supplies in the PD which feed the Crio, the Wireless Bridge and the camera drop out at ~4.5 volts at the battery input to the PD. The Crio is programmed to disable all outputs at 5.5 volts in order to try to protect itself from reboot. Heavy motor use will pull the battery down to these critical levels for short periods of time without causing any problems, but a robot that is not designed with efficiency in mind, will cause some or all of these items to fail without warning.
A Crio disable is pretty obvious with a sudden jerky movement or response under driver control. If the battery goes down to less than 4.5 volts for more than a moment, the Crio and/or wireless bridge and/or camera will reboot. The Crio can take anywhere from 20-60 seconds to reboot depending on your software. The wireless bridge can take up to 50 seconds or more to reboot and reconnect to both FMS and the Crio. The power supplies will restart very quickly when the battery returns to more than 5-6 volts.
Please remember, the battery has some internal resistance, your wiring has some resistance, the circuit breakers have some resistance. When you pull a lot of current from the battery, the current passing through all this resistance will drop the voltage available to critical items like the Crio and wireless bridge power supplies. #6 wire has ~0.0005 ohms per foot and the battery has 0.011 ohms at full charge and room temperature. An average robot with 4' (both red and black musst be considered) of #6 with four CIMs in stall while pushing another robot will drop a minimum of ~5.2 volts in the resistance in just those components taking the available voltage to 6.8 volts at full charge.
Unread 20-02-2012, 08:39
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
I second moving the Window Motors to a 20A or 30A amp breaker. You'd have to try really darn hard to get more than 20A out of those.
You are using your FPs for your shooter, which is a free-spinning mechanism. That means it will likely only operate in the low-current regions of your torque curve. That also means it is certainly possible to put them on a smaller breaker, if you are very sure there is no chance of stalling your shooter (i.e. stuck ball).
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 20-02-2012, 10:07
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
All 4 of our shooter motors are on 20A breakers, no problems so far. Of course we are running them in a "sweet spot" on their power curve, they are not getting the slightest but warm.
HTH
