Go to Post If you find yourself extremely upset, frustrated, angry, or any other term of emotion, please stop and ask yourself why you participate in FIRST. - indieFan [more]
Unread 17-02-2012, 01:57
Lalaland1125 Lalaland1125 is offline
AKA: Ethan Steinberg
FRC #2429
Lalaland1125 is an unknown quantity at this point
Are we allowed to put a resistor on the robot
Our team has two 12V and two 24V solenoids, all of which we need to use.
We were thinking that we could power the 12V solenoids off the 24V solenoid breakout with a ~273 ohm resistor(from our math/measurements).
(We also tested with a 300 ohm resistor and it worked)
Is this legal for competition?
(We know that the "suggested" method is to use spikes, but if this is legal it would heavily cut down on the wiring, programming, space use, etc).
Unread 17-02-2012, 08:15
Re: Are we allowed to put a resistor on the robot
I won't comment on the legality of modifying the power path going to a pneumatic solenoid valve. I will instead suggest an alternative:
Use a second Digital Sourcing Module and Solenoid Breakout, powered by 12 volts. The power distribution diagrams include an example of this usage.
Or replace two of your solenoids so they all use the same voltage.
Unread 17-02-2012, 08:43
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Seems to be against the rules with [R47]
[R47]
Custom circuits shall not directly alter the power pathways between the battery, PD Board, speed controllers, relays, motors, or other elements of the Robot control system (including the power pathways to other sensors or circuits). Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the Robot’s electrical system is acceptable, if the effect on the Robot outputs is inconsequential.
Unread 17-02-2012, 08:44
You can drive your 12 volt solenoids from a Spike. Remember that the two output pins on the Spike can be driven independently if the common on the solenoids is tied to battery common.
You may not use resistors in that application.
