Go to Post There's a balance to it all, when the engineers guide the students, and both cooperate to build a robot. There can be no better way then when both sides are in cooperation - the true spirit of FIRST. - Jim McGeehin [more]
Unread 17-02-2012, 09:36
guoruiwu1994 guoruiwu1994 is offline
FRC #1815
guoruiwu1994 is an unknown quantity at this point
Using PID controls to center robot on target with camera
Using the camera, we can get how many pixels we are off target. Is there a way to feed that into the PID controls and then have the PID controls output into the robotdrive?
As far as I know, in the provided PID function you have to give it a source (such as an encoder), you cannot give it a number. Also, I'm not sure if the PID output works with robotdrive (arcade mode).
