Go to Post Were going to nationals!?! Did anyone think of telling me this? - Beta Version [more]
Unread 17-02-2012, 09:36
guoruiwu1994 guoruiwu1994 is offline
FRC #1815
guoruiwu1994 is an unknown quantity at this point
Using PID controls to center robot on target with camera
Using the camera, we can get how many pixels we are off target. Is there a way to feed that into the PID controls and then have the PID controls output into the robotdrive?
As far as I know, in the provided PID function you have to give it a source (such as an encoder), you cannot give it a number. Also, I'm not sure if the PID output works with robotdrive (arcade mode).
Unread 17-02-2012, 09:40
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Using PID controls to center robot on target with camera
Are you programming in the command based style? If so it is actually really easy to do with a PID subsystem.
Unread 17-02-2012, 10:35
FRC #1815
What do you mean by command based style?
Unread 17-02-2012, 10:40
See the WPILib Cookbook located in the Documents area on the WPILib FIRSTForge project:
http://firstforge.wpi.edu/sf/go/doc1297?nav=1
Unread 17-02-2012, 10:42
FRC #1815
Right now, we are using IterativeRobot.
Unread 17-02-2012, 10:50
Flywheel Police
You will have to create your own PID class that extends the current PID class and override some of the methods to get it to work the way that you want it to.
Unread 17-02-2012, 10:53
FRC #1815
Can you give me some example code on how to do that?
Unread 17-02-2012, 11:07
Flywheel Police
Unfortunately there isn't really any example code, and I don't have any written right now.
Unread 17-02-2012, 11:36
A PID takes a setpoint and a processVariable as inputs, and adjusts its output to make the plant's output (the processVariable) equal to the setpoint.
You want the "how many pixels we are off target" to be zero, right?
So your setpoint would be 0 (zero), and "how many pixels we are off target" is your process variable. The output from the PID would be your drivetrain rotation command (assuming that "how many pixels we are off target" is a measure of aim, not range).
Unread 17-02-2012, 11:40
FRC #1815
The input of the PID wants a source though, not a number.
Unread 17-02-2012, 11:56
Flywheel Police
http://www.wbrobotics.com/javadoc/ed...PIDSource.html
Create a new class that extends PIDSource and rewrite the pidGet() method to get the offset of the target from 120 and return that value.
Unread 17-02-2012, 12:11
Give it a source that always returns zero for the setpoint.
Give it a source that returns "how many pixels we are off target" for the processVariable.
Unread 18-02-2012, 14:33
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
https://github.com/jesusrambo/PurpaD...tRotation.java
Look through VerticalTurretRotation and HorizontalTurretRotation, that's how we do it.
