Go to Post 118 embodies everything this entire program is supposed to be about: INSPIRATION. Respect that. Acknowledge that. Support that. - barn34 [more]
Unread 17-02-2012, 11:50
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Joystick getThrottle() returns 0
I'm having an issue getting the throttle position of the joystick. When I call the getThrottle() method on joystick the value is always 0 regardless of the throttle position. Below is the code I am using:
OI.getInstance().getDriverJoystick().getThrottle() ;
OI.getInstance().getDriverJoystick().getAxis(Joyst ick.AxisType.kThrottle);
When I make a call to get the stick x-axis position it works fine. Value is between -1 and 1.
OI.getInstance().getDriverJoystick().getAxis(Joyst ick.AxisType.kY);
Is there something I am missing here?
Unread 17-02-2012, 12:55
What joystick are you using? Does the throttle show up on any of the 6 axes?
Unread 17-02-2012, 15:11
Re: Joystick getThrottle() returns 0
It's the Logitech Attack 3.
Not sure what you mean by "the throttle show up on any of the 6 axes"...
In software I'm using the wpilibj Joystick class. Below are the default axes:
static final byte kDefaultXAxis = 1;
static final byte kDefaultYAxis = 2;
static final byte kDefaultZAxis = 3;
static final byte kDefaultTwistAxis = 3;
static final byte kDefaultThrottleAxis = 4;
static final int kDefaultTriggerButton = 1;
static final int kDefaultTopButton = 2;
Is the throttle a different axis on this controller?
Unread 17-02-2012, 15:24
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Well, I'm looking at our Logitech Attack 3, and I'm not seeing a throttle. You should just use getX, getY, and getZ.
This is what a joystick throttle looks like.
Unread 17-02-2012, 15:33
I figured it out... the throttle on the Logitech Attack 3 is axis 3 (defined as the twist axis in the wpilibj Joystick class).
Patrick: Not sure how to attach an image... but ours is a single stick "fighter jet" style controller different than your picture.
Thanks for the help!
Unread 17-02-2012, 15:38
Picture of our Logitech Attack 3
http://www.logitech.com/gaming/joysticks/devices/302
Unread 17-02-2012, 15:41
Programming
Glad you figured it out.
I know what an Attack 3 looks like; I'm looking at one. The picture I linked is what a throttle looks like, and an Attack 3 doesn't have one of those.
Unread 17-02-2012, 16:07
My confusion mainly came from the image of the Logitech Attack 3 in the WPILib User's Guide. It annotates the dial/lever on the rear of the controller as a "throttle".
http://http://firstforge.wpi.edu/sf/...tion/doc1196/2
Unread 17-02-2012, 16:23
Logitech never explicit labels the wheel at the base of Attack 3. What would you call it? Colloquially, many people call it a throttle. http://www.amazon.com/gp/community-c...sin=B0000ALFC5
Unread 17-02-2012, 18:50
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
It can be referenced with getRawAxis(3) or more simply getZ()
It is the 3rd axis since the Logitec Attack doesn't have a Z/twist.
Also, I don't understand what you're calling the joystick through. What is OI?
