Go to Post Who would have thought a triangular robot would fit into a triangular goal :rolleyes: - Wayne Doenges [more]
Unread 14-02-2012, 16:18
Piccolo Piccolo is offline
FRC #0383
Piccolo is an unknown quantity at this point
Axis camera setup problem (Axis 206)
My team is having some problems concerning the Setup Axis Camera Tool: when we try to apply the robot radio setup to our camera, we receive a message saying that the program can't reach the camera and we must create manually a "FRC" user with "FRC" as password. So we created this user, but it keeps showing this message.
Notes:
-The program is able to connect to the camera.
-The camera IP and PC IP were set as the Setup Axis Camera required.
Thanks
Unread 15-02-2012, 10:29
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
Re: Axis camera setup problem (Axis 206)
Notes:
Thanks
Remember that before you configure the camera, its IP is (should be) 192.168.0.90 and your computer should be connected directly to the camera by ethernet with its Wired Connection IP set to 192.168.0.11 if I recall correctly. If it isn't showing up on the setup tool, reset the camera by holding the reset button as you plug in power and until the front lights turn on, and double check your computer IP.
When you have your camera set to 10.te.am.11 (through the manual settings or otherwise) and have made the FRC user, login to the FRC user and ensure you have Allow Anonymous Viewing enabled.
Unread 15-02-2012, 14:20
FRC #0383
We've tried all these configurations, but we had no luck so far. The Axis Camera Setup keeps the same error. We've even tried to build a new dashboard project. We ran without errors, but no image appeared. Is there any update or new documentation concerning the camera?
Thanks for the help
Unread 15-02-2012, 14:30
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
Thanks for the help
To connect to the camera from the PC you have to set your pc subnet to 255.255.255.0 not 255.0.0.0 or else it will not connect and try in cmd to ping it by doing "ping 10.te.am.11" and see if that works, if not then try configuring your camera with that subnet and the crossover cable not the ethernet.
Unread 17-02-2012, 14:07
FRC #0383
We changed the subnet and the IP. We are able to connect to the camera, but not to surpass the "Unable to login. Create manually a "FRC" user." error screen, even though we create the FRC/FRC user.
