Go to Post If they ask you to stop - you stop. - techhelpbb [more]
Unread 17-02-2012, 11:21
bakejame's Avatar
bakejame bakejame is offline
FRC #2993
bakejame has a spectacular aura aboutbakejame has a spectacular aura aboutbakejame has a spectacular aura about
2 Signal lights?
We were wondering if we can put on two signal lights. I have looked through the rules and it only says that we have to have a signal light. It doesn't say anything about having two. I know we don't need two, but it looks much cooler with two. (They kind of look like headlights.) Can anyone confirm either way on this?
Thanks,
Jim
Unread 17-02-2012, 11:43
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: 2 Signal lights?
I would expect if you asked the GDC the answer would be only one. Mount it in the middle & call it Cyclops? On the other hand the worse that would happen is your inspector would make you take it off.
The light serves an important function. You should not have a decoration that comes close to what the RSL looks like.
Unread 17-02-2012, 11:59
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Talking Re: 2 Signal lights?
i don't know about this year but we had two on our robot last year until at the first regional we were told to remove it. the issue was that the lights were (cause of the wire) on a delay that wasn't noticeable at first but got progressively worse when we started playing practice matches. i don't know for sure but i would assume that this hasn't changed. if your not sure then just put it on and if you gotta remove it then oh well.
Expect the best, Prepare for the worst
Unread 17-02-2012, 12:14
R57 refers to the RSL in the singular use for just that reason. One and one only please.
Unread 17-02-2012, 12:18
I'm a bit confused here. There is nothing in the control system that is aware of how many RSLs are attached, and nothing that could be delayed by the presence or absence of those lights.
Unread 17-02-2012, 12:27
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by Rules
[R57]
Robots shall use the diagnostic Robot Signal Light (RSL) provided in the KOP. It must be mounted on the Robot such that it is easily visible while standing three feet in front of the Robot.
A. The RSL must be connected to the “RSL” supply terminals on a Digital Sidecar
B. The Digitial Sidecar must be connected to a NI 9403 module in Slot 2 of the cRIO.
C. The RSL must be wired for “solid light” operation, by placing a jumper between the La and Lb terminals on the light per Figure 4‑9.
I see nothing in the rule that prohibits multiple RSLs.
That being said, expect resistance from some inspectors and be prepared to remove the extras should the head inspector require you to do so.
Al, specifically, why would you have issue with multiple RSLs?
___________________
- Tennyson, Ulysses
Unread 17-02-2012, 12:36
Daniel,
I don't. The GDC specifically responded via Q&A on this point last year, one and only one. The rules this year in the singular reflect that decision.
2011 Q&A Response
Rule <R54> permits only one RSL, part number 855PB-B12ME522.
2011 R54 is virtually identical 2012 R57.
The RSL flashes specific codes for use by the FTA so they may assist you to play.
Unread 17-02-2012, 12:42
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel,
2011 Q&A Response
Thanks for the quick response.
2 years ago we used 2 RSLs and did not have any issues with either inspection nor implementation. Hense my questioning your response.
I did not see the Q&A on this last year, but since it needed a Q&A answer one wonders why they didn't clarify it in the rules this year. I guess it's just a missed continuous improvement opportunity.
___________________
- Tennyson, Ulysses
Unread 17-02-2012, 14:11
Daniel,
There has been a planned reduction of the rules this year and this is one of those that was likely intentional. If you have any suggestions (like adding specifics) please let First know.
Unread 17-02-2012, 14:37
mikets's Avatar
mikets mikets is online now
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Let me step back a bit and ask: why do you need two RSL lights?
Unread 17-02-2012, 15:07
bakejame's Avatar
FRC #2993
Thanks for all of the responses. I think we are going to go ahead and leave the second one on and see what happens. It is really easy to remove and we do have another spot we can move it to if needed. It just looks so cool with both of them on it.
Unread 17-02-2012, 17:57
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Seems like the worst ever reason to ignore advice from the Chief Robot Inspector for FIRST.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 17-02-2012, 19:19
BioWolf's Avatar
BioWolf BioWolf is offline
AKA: Arandy R
FRC #2375 (The Dragons)
Team Role: Electrical
BioWolf is an unknown quantity at this point
wait.
quick question.
so i cant find the minimum AWG for the RSL. can anyone help me?
Unread 17-02-2012, 19:35
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally Posted by BioWolf View Post
wait.
quick question.
Q&A said there isn't any (2012 question 386).
Use what's recommended by the manufacturer for the 855PB-B12ME522 panel signal device: "up to 2.5 mm2 (14 AWG)". I'd avoid going smaller than 30 AWG for solid wire, or 24 AWG for stranded wire, mostly for ease of use; it only draws 60 mA, so capacity isn't a big issue.
Last edited by Tristan Lall : 17-02-2012 at 19:40. Reason: Two recommendations for solid and stranded.
Unread 20-02-2012, 07:32
Bio,
I usually recommend #22-#18. It is easier to terminate in the screw terminals at the base of the light.
bakejame,
I can guarantee all inspectors will/should share the same opinion, one and only one RSL.
