Go to Post A robot that does 60% of the tasks 100% of the time is better than a robot that does 100% of the tasks 60% of the time. - artdutra04 [more]
Unread 17-02-2012, 15:03
stintzi stintzi is offline
FRC #3290
stintzi is an unknown quantity at this point
Gyro/Range finder not functioning properly
I've posted my code for the teleop and my dashboard. I have never created a custom dashboard and would like to call you all to check my High Priority Data to ensure that is all set up properly.
My gyroscope has never functioned properly, it is the 2010 split up Accelerometer/Gyroscope. I have my gyroscope hooked into Analog Module 1 in port 2.
My range finder is hooked into port 1. It used to work properly, but now it doesn't. When I power it and monitor the analog signal with a multimeter I get a fluctuation from 0 to 1 V when I point the range finder around the room. However, on the dashboard it only ranges from about 2.5 to 3 and once and stops changing after a bit.
I am using the Range Finder that came with the 2012 KOP. Attached are my Teleop.vi and Dashboard.vi. I am using the 8 slot crio in the analog module 9201.
Unread 17-02-2012, 20:05
FRC #3290
Re: Gyro/Range finder not functioning properly
Everything appears to be hooked up, electrically, correctly.
Unread 18-02-2012, 12:53
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Wolfgang is an unknown quantity at this point
My team tried playing with the rangefinder as well. The max distance is supposedly about 21 ft (not 100% sure), but it starts becoming very noisy after the distance is 8 ft. The data fluctuates widely even when it is quiet, when it is noisy. For this reason, my team has decided not to use the rangefinder.
Unread 19-02-2012, 09:46
FRC #3290
Could something be wrong with my cRIO module?
