Go to Post Don't worry about where you will be. Just consider youself lucky for being where you have been. - sanddrag [more]
Unread 22-12-2001, 15:57
EZRider EZRider is offline
Mr Ed
#0648 (QC Elite)
EZRider is an unknown quantity at this point
Question Motor Gear Info
Can anyone tell me what the pressure angles (14 1/2 degree or 20 degree or ??) are for the 12 tooth gear that is mounted on the shaft of the drill motor, and the 16 tooth gear that is on the Fisher Price motor? And does anyone have a source (Supplier and part number) for replacements for either of these?
Unread 22-12-2001, 17:35
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
The gears are 20 Degree pressure angle.
The 12T drill pinion is 0.7 module.
The 16T F-P pinion is 32 D.P. (English units for Diametral Pitch vs. Metric Module)
The drill pinion is available from Skil-Bosch service parts. I think the entire F-P motor with pinion is under 20 bucks and I don't think it is available separately.
To my knowledge PIC-Design is the only company that sells .7 module gears "off the shelf" When off the shelf gears were legal, I used them to buy a mate to the drill motor.
Perhaps FIRST has relaxed the gear sourcing rule, but I suppose that they have not.
If you want to mate to that gear you will have to get one custom made from legal kit materials. We have always had them wire EDMed from 1/4 steel plate. It works well for us.
Joe J.
Blue Man Group FIRST get-together? Gui Cavalcanti Chit-Chat 11 16-09-2003 18:11
Chesapeake Regional - need info! Jferrante Regional Competitions 15 15-03-2003 21:03
TEam 401 contact info Andrew Rudolph General Forum 1 17-05-2002 00:24
Langley / VCU Regional team info gildorr Regional Competitions 5 22-02-2002 15:50
TEAM 126????? I need info!!!!! HELP CMC General Forum 5 10-12-2001 11:26
